    Registered Member Two Rings
    Mar 24 2008
    there
    A/C power loss/gas mileage question
    I have a couple of questions on using A/C. If it's hot outside, I put it to "LO". I'll most likely keep it on LO until recently. I'll gradually increase the temp while remaining comfortable.
    So the question is, does it help gas mileage at all by increasing the temp? Is the A/C system being used less, saving gas?
    In the same way, does it also rob less power? When my A/C is on, I feel bogged down. Does the A/C rob more power on LO compared to say 70 on the left and right?
    I have a 3.0l if that matters.
    Thanks.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: A/C power loss/gas mileage question
    The AC will rob power regardless of the temp setting, as long as its on.
    Try driving a 1.8T with the AC on if you think you're having issues!
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Mar 24 2008
    there
    Ha, right on.
    Sounds like I'll treat myself to ice cold air then.
    Jun 12 2008
    Warminster, PA
    Quote Originally Posted by DZA View Post
    Ha, right on.
    Dont skimp on the chillies
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    for most vechiles,
    in city with AC on will consume up to 10% more fuel.
    in highway it doesnt make that much difference.
