Results 1 to 7 of 7
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    GTRS n Full boost with Stock Cat
    Hi,
    Running Revo GTRS but only at 14psi atm. Will it be dangerous to run the turbo at full boost with stock cat? i only have cat-back exhaust (magnaflow) and will most def be changing it asap. but in the meantime, will it be dangerous to run it at max boost?
    Thanks,
    Starfriend
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: GTRS n Full boost with Stock Cat
    i wouldn't, i suspect that is why my K04 died and have also heard stories of others having the same issue.
    Oct 29 2005
    10speed
    San Francisco, CA
    well, your basically going to SERIOUSLY heat shit up there... You can do it, but Id keep a big eye on EGTs
    - Clint
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Even on the stock K03, REVO stage 2 (injector file), it is susposed to be detuned (lower boost/timing settings) if you don't have a test-pipe and Full exhaust. My local dealer said that its to prevent premature turbo failure due to too much back pressure.
    That's on a K03...I def wouldn't suggest it on a GTRS.
    I have the REVO BI file and an ER TP (AWE exhaust in shipping now ). Before the TP I could heat the stock cat up pretty good (I don't have logs), but the stock cat/turbo would visably be starting to glow red after a hard run. Now the turbo may show a little...but no where near as bad as before the Test pipe.
    Oct 17 2007
    A4 GTRS
    Norway
    hmm, running my gtrs @ 0.7BAR (12psi ish i think) i only get eGT's of max 750 @ 3rd gear pulls.. only tried like two tho, to be sure at least i can drive the car meanwhile im locking for a local exhaust shop to get the cat and downpipe switched out. Thanks a lot all.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Ran mine on a stock cat and stock manifold up to 18 PSI for a while and it did just fine.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Well I think thats why my k03 died i had a bad cat and that sucker use to GLOW BRIGHT RED!!!... Once I put the test pipe on it was ok... then it died ... :(
