Results 1 to 4 of 4
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    headlight fog...
    I've been doing a 'joey mod'' few weeks ago without issue but its raining here for almost 6-7 days and I see a little fog into both headlight. I did take a long time to seal the lense when I did the mod. I used a body sealer that seems like rubber when dry and I thought it s a good stuff to seal it right. Does anybody experienced it and what do you thik I should do??? Should I remove bulbs and dry the inside I then put back bulbs?? Any idea? Is there a oneway vent on the headlight?
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    Re: headlight fog...
    just start driving around with your headlights caps off so that air can go in and dry it out.
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Jan 10 2007
    VA
    If you sealed the lights well, water is probably leeking in through the headlight adjustment screw. water runs down the fender edge under the hood and funnels right onto this screw. I swapped out my O-rings and all fog/condensation is gone.
    Search for headlight condensation or similar.
    Aug 26 2005
    Quote Originally Posted by b6onboost View Post
    Remember this O ring fix is only associated with the BiXenon S4/A4 housings with the single rear housing cover. The non Bixenon housings with the two small rear covers don't use the adjuster with the O ring seal.
    To the OP, the housings are not sealed at all, they are fully vented, If the fogging is only a very light misting on the lens, that is normal. The other situation is heavy, persistant condensation that never clears away completley. If the condensation on the lens consists of heavy water droplets, that is more or less always present, then you need to remove the housings and completely dry the interiors of the housings. There is some tight spots in the bottom of the housings that traps water, use a hair dryer to make sure the water is completely dried out. Then, find out where the water is leaking into the housings and fix the leak.
