Results 1 to 18 of 18
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    is there any fuse that offers power for a delay, AFTER you lock the car?
    I want 12v switched power for a duration of time after I lock and unlock the car. TIA! I thought the radio fuse would have it...but I had 12v switched for a LONG time afterwards
    Mar 11 2008
    B7RS4 & e46Ms
    Re: is there any fuse that offers power for a delay, AFTER you lock the car?
    how long of a duration?
    DEI makes pulse timers (basically switched relays) that will activate for an adjustable time period. But IIRC, 90sec was the longest it would go...
    What is it you're trying to accomplish? what's the end goal?
    Mar 09 2005
    Santa Clara, CA
    i want my LEDs to stay on for like 10-15 seconds after I lock/unlock my car, much like the feature with the fogs. right now the LEDs trigger a relay when there is 12v switched (off the sunroof)
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by ngng View Post
    ...what I would do...
    the lock wire is a negative trigger, brn/gry or red/brn wire in either the driver's kickpanel or off the factory alarm, which should be at the bottom pass side of the trunk. My A4 is different, so I can't verify this for you...you'll have to tap and test them yourself...and please be carefull...
    use that negative trigger to activate the pulse timer (the pulse timer wires up like a SPST relay) which you can wire in with your LEDs.
    if you want the same effect with unlock, it's also a negative trigger, gray/wht wire in the same location(s) as the lock wire. You can use it to activate the same trigger on the pulse timer. The trick here is to diode isolate both the lock/unlock wires to keep them from working against one another...
    15 sec is definitely possible with that relay and should work just fine.
    Mar 09 2005
    Santa Clara, CA
    mthanks. was hoping for a fuse or wire i could tap :P but it might come to that
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    What about the dome light, you can set it to stay on and fade a few secs after you lock it, maybe you can tap into that some how. IDK...?
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Dec 06 2007
    ^^hey did the guy ever reply to u about the S4 bi-xenons??
    sorry for the threadjack
    -Kirk
    BetaAlphaTau Member #58
    Feb 07 2008
    Orlando, FL
    Quote Originally Posted by AudiA4Turbo22 View Post
    No! Not a damn thing.
    15 S6 4.0T Quattro
    Dec 06 2007
    ^^i think the classifieds are screwed up i've made offers for several products and none have returned!
    -Kirk
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Dirty View Post
    i tried BOTH fuses for central convenience...but no dice :/
    Mar 11 2008
    B7RS4 & e46Ms
    I doubt it would be directly off the fuse... the fuse will run to the module that actually times out...
    why not just tap off the fog lights?
    Mar 09 2005
    Santa Clara, CA
    I bypassed the stock wiring entirely for the LEDs, I wabted to be able to run these as DRLs that come on with a switched 12. If I tapped the fog wires, I got all kinds of DIS errors AND I couldn't run the lights independently.
    I just came to thinking tonight, it would be sexy if the lights stayed on for a little after I locked/unlocked the car. Just a spur of the moemnt kinda thing
    Mar 09 2005
    Santa Clara, CA
    any other suggestions?
    Mar 11 2008
    B7RS4 & e46Ms
    When you originally tapped the fogs, did you use those leads to power the LEDs? or did you run them to a switched relay for the LEDs?
    Assuming you can get the LEDs to work through a relay without DIS issues (may have to add in resistance, but the relay should provide enough) You could actually use the LEDs as DRLs and keep them on using the fog's circuitry as well...
    You'll use the two leads from the fogs to the 85 & 86 points on the relay (if you get DIS problems this way, try just using the switched wire in the fogs for 85, and use a static source for 86) You'll run 30 to the +12v line on the LEDs, the gnd of the LEDs to static gnd. Run the NC (87a) pole of the relay to a 12v switched lead from your igntion harness, or some fuse that's only on when the car is on (DRLs). Run 87 to a constant 12v source.
    Let me know if this makes sense, or if you need any further detail...
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    If I were to do this, depending on the amount of power the switched side of the circuit takes (the side that activates the relay), I would isolate it with a diode, then use a resistor + capacitor to decay the signal. Component sizes dependent on how much current flows through that side of the circuit. Or perhaps do this to the LED side of the circuit, so it gradually fades off. Also dependent on the specific circuit. Are you LEDs just a separate on/off thing? Or are they wired to the park lights or turn signals?
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I agree on tapping into the dome lights.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by B6 Dude View Post
    i'll have to look it up, it's a standard bosch relay.
    the LEDs are independent, I can wire them to whatever i want
    May 31 2008
    Palm Beach, FL
    The LEDs should have a current-limiting resistor. So a diode and capacitor should give you a nice fade out. If you have the circuit diagram, I can probably help you figure it out.
    Cheers,
    -Neil.
    Audios,
    -Neil.
