Results 1 to 19 of 19
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    TPMS on Aftermarket Wheels
    For you guys that have changed out your wheels, how have you dealt with the TPMS (tire pressure monitoring systems) on the newer model a4's
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Senior Member Three Rings B6QTRO's Avatar
    Nov 05 2005
    2007 A4Q S line 2006 A6 Avant
    Downers Grove, IL
    Re: TPMS on Aftermarket Wheels
    I purchased a new set of wheels for my wife's A6 that did not have the TPMS so I ended up buying them through tire rack
    07 S line Titanium PKG
    Koni Coilovers | RS4 Grill | RS4 Recaros | Lamin X Fogs | Miltek Sport |OEM RS4 BBK | AWE Boost Gauge |
    APR | RNSE | 19" Champion Motorsport RF62's| Carbonio | Ultrac Sessanta | V1 Hardwired | RS4 Rear Sway |
    | Carbon Fiber Interior Trim | Blacked Out Front/Rear Rings | RS4 Pedals | Skid Plate | Phat Box | 35% Tint |
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    take them off your stockers and put them on your aftermarket wheels. should work in most applications without a problem.
    Jan 16 2008
    Ohio and GTA
    okay, i figured they would work, but tire rack said i needed to purchase new ones(most likely a sales gimick because they were like $350)
    Nov 05 2005
    Downers Grove, IL
    Quote Originally Posted by nick71692 View Post
    your old ones will work, I bought a set as I kept the stock wheels for the winter
    DUH! an Audi
    los angeles, CA
    will work, just take off your stocks and put on your aftermarket...did this for my sis car
    Established Member Two Rings Dcting's Avatar
    Mar 25 2008
    Forest Hills, NY
    Does anything need to be vag'd??? Or is it pretty much a direct transfer with no adjustments necessary?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The TPMS sensors are inside the tires attached to the valve stem. You can reuse the sensors from your stock wheels, but you will have to dismount the tires first.
    Purchasing a second set of sensors is another option. That way you have 1 set always on standby for that next set of wheels/tires.
    The last option of course is to just disable the TPMS sensors using the VAG.
    May 21 2008
    $350??? They're around $40 at the dealer's parts dept. You don't VAG anything unless you want to disable TPMS monitoring. Just reset the tire pressure memory.
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    Quote Originally Posted by Mike@PureMS View Post
    Mike,
    would you tell us (or at least me) how to disable the TPMS reading through VAG?
    dealers say it can't be done, but I'm wondering if anyone has successfully done this on an '08 A4.
    thanks!
    Last edited by kooltechie; 08-06-2008 at 10:01 PM. Reason: corrected wrong thumb direction :P
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by ibiski View Post
    You need one sensor (4F0 907 275 b) and one valve stem (4D0 601 361) per corner. At Audi list prices, that's $86.15 for each sensor and $26.60 for each valve stem or $451 for all 4. Even with discounts from, say, GAP, you're looking at $311.16/set
    May 21 2008
    Quote Originally Posted by mksap11 View Post
    That's really weird, because I had to buy one from my dealer (the tire shop broke one of the rubber seals during wheel swap) and it comes as a whole set (sensor, stem, seals and washers) for $41.
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    what kind of aftermarket wheels?
    if 2 piece or 3 piece you need adapters to make the TPMS work on those wheels
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Apr 06 2005
    Boston, MA
    The sensor comes separately from the valve stem. Most likely, they replaced only the valve stem and over charged for the part like one of the Audi dealers in my area likes to do.
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Quote Originally Posted by kooltechie View Post
    Mike,
    thanks!
    Yes, it can be done. I did it on my 2008 A4. This is what I did on my VAG-COM:
    1) Go to 17-Instruments
    2) choose Adaptation
    3) choose Channel 61.
    4) Subtract 512 from the value you find there.
    no more TPMS!
    I have 4 set of wheels/tires and there was no way I was going to buy sensors for them all. I check my pressures often anyway so I don't need TPMS.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Sep 04 2007
    Pasadena, CA
    Quote Originally Posted by tre View Post
    no more TPMS!
    great!
    I found the same info on audiworld a while ago, but no one confirmed it worked.
    another question:
    do I need the full version of VAG-COM or does the ebay one work as well?
    TIA!
    May 21 2008
    I bought the set myself at the parts counter. I wanted to buy just the stem with the rubber seal, but they showed me that it comes as a whole set with the sensor. I have an '08, so maybe it's different for earlier models, but I doubt it.
    Apr 06 2005
    Boston, MA
    Not according to ETKA. Part No: 4d0601361 (11) is for the "metal valve for models with tyre [sic] pressure monitor (wireless radio sys.)" and lists for about $27. The sensor is a completely different part: 4F0907275b (10).
    You can also go to http://www.genuineaudiparts.com and plug those part numbers in to see what I mean.
    Jul 07 2008
    Chicago
    great!
    another question:
    TIA!
    I have the Full version of VAG-COM. I don't know anything about the ebay version.
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
