    Senior Member Two Rings suju82's Avatar
    Jun 02 2007
    1999.5 a4 1.8tq k04+giac, tt dv, bosch 4 bar fpr, DP back 2.5" magnaflow, k&n drop-in.
    Toronto, Canada
    Unhappy Need help, car isn't working right.
    audi a4 1.8tq. Car had been sitting for about two months or so and decided to drive it again. Started fine and drove fine for about an hour or so. Then all of a sudden as i taking the exit off the highway it started loosing power and the cel started flickering on and off. Car would loose all power while still rolling and then when i gave it gas the power would come all of sudden for a second or so and go out again and kept doing that all the way home. parked it for about an hour and then drove and it drove completely fine and boosted good and pulled hard on the highway and everything when i drove about 20 km and the same problem started happening again. CEL flickering and now is on and power would come on all the way when i give it gas and would cut out in a second. I scanned it and got these codes.
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 557 P
    Component: 1.8L R4/5VT MOTR HS D00
    Coding: 06201
    Shop #: WSC 03023
    5 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    P1559 - 35-10 - - - Intermittent
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-00 - -
    16988 - Internal Control Module: RAM Error
    P0604 - 35-10 - - - Intermittent
    17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :-)
    P1560 - 35-10 - - - Intermittent
    Readiness: 0110 0101
    Address 08 -------------------------------------------------------
    Controller: 8D0 820 043 N
    Component: A4 KLIMAAUTOMAT D54
    Coding: 00040
    Shop #: WSC 06335
    Note: Excessive Comm Errors
    Also what is the 8d0820 043n thing as the vag just got stuck and stayed there for a few minutes until i closed it and then finally went on to scanning the next thing. Please let me know otherwise the car will go to the mechanic tomorrow.
    Jun 02 2007
    Toronto, Canada
    Re: Need help, car isn't working right.
    Also alternator and battery were replaced right before it was parked and so was the central locking pump.
    Jun 02 2007
    Toronto, Canada
    This website is almost useless. People only reply to problems that are common and for which an answer has been posted a million times already. No one really knows what they are talking about as i never get any replies whenever i post something on here.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Did a search of your posts Suju, and I see many replies to questions put up. you don't want loads of bogus advice from post-happy n00bs, right? There are other VAG websites that can fulfill that nightmare out there.
    All I can suggest is you have a shop check your battery connections & battery again, reset all of those codes and then see what happens.
    chill for like a minute and maybe someone will be along to assist. I mean I know its frustrating when your ride isnt right. Search function at the top of each forum page is serviceable if you have the time.
    Registered Member One Ring tbonetyler's Avatar
    Oct 27 2008
    1982 Fiat Spider 2000, 1996 Subaru Legacy, 1985 Toyota Pickup,
    Juneau, AK
    I know this an old thread but did you ever figure out what was wrong???... I have the exact same symptoms and 3 of the same codes..
