Results 1 to 36 of 36
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Help me pick a fitment for my CCWs
    ill be ordering CCW classics as soon as i sell my bike..
    that being said
    i want some minor poke.. nothing crazy.. and some decent lips(dont have to be 3 inch lips) but u get the idea.
    im thinking
    18x9 all around
    ET30 in the rear and ET34 in the front..
    i dont know how this will fit as i may need a spacer so i may just have to bump it down to ET32 rear and ET36 front.
    EDIT.. oh yea i have the ECS tuning porsche 993 BBK
    anyone have experience with a similar fitment?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Feb 28 2007
    chicagoland
    Re: Help me pick a fitment for my CCWs
    Similar to the rear of this car.. maybe a bit more poke
    Nogaro 01 s4
    620whp 93octane
    Feb 28 2007
    chicagoland
    actually pretty much exact fitment as this. but in an 18.. who is the owner of this car?
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i clicked on the image path and its a photobucket album hosted by velocitys4. im assuming its his car.
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    you better have exact measurements for those brakes. ccws wont clear a bbk very easily. they will make spacers for you. great wheels, great service. i hope thewy clear those brakes. keep us posted
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Black car is Pat-SoCal. Long time AW poster. That car is now fully caged with OEM/SDR widebody with areo kit. Full-on race car. I believe when he was running his CCW's he also had some fender pulling done to get them to fit.
    Veteran Member Three Rings slammed_nogaro's Avatar
    May 10 2007
    CHICAGO
    what tires size did you want to run?? if you do a 225 id do... 18x9 27et front and 23et rear... bc when i had my lm reps i ran a 10mm spacer in front on a 18x8.5 35et which made it a 25et, but on a 8.5. it was flush... so 9 with a 27 et would be perfect id say and just run a few lower et in the rear. you can allways roll or pull a little more, id hate to order expensive ass wheels and not be perfect lol. a few mm isnt too big of a difference.
    Feb 23 2005
    ccw's are made to order. when you place your order they have all the measurements you would need in the computor. i was on the phone for quite a while getting mine done. the fronts have a bit too much poke [they send spacers, i just need to get a few mm's taken off the front] the rears i spaced out 10mm. the rears are perfect now. the fronts rub under hard bumps. they had to spaced like they are because i was planning on going with a bbk. John [ the owner of ccw] said these wheels are hard to get bbk's under.
    Dave
    Feb 28 2007
    chicagoland
    Quote Originally Posted by slammed_nogaro View Post
    Hmm... i dont wanna hve to mod too much on the car to get them to fit.. id rather play around with like a 5mm spacer to put it at the above specs ^ in case its a little too much work to get them to fit.
    that being said..
    18x9 32et front
    18x9 27et rear?
    thaty way the front will leave me room for a spacer to get the fitment i want.. although like you said its only a few mm.
    the Rep from CCW recommended et23 in the rear and et38 in the front.
    id like to have a little more than that in the frno though.
    Nogaro 01 s4
    620whp 93octane
    Feb 27 2007
    Chicago
    Quote Originally Posted by Dr. Jekyll View Post
    This is correct info. I now own those CCW wheels and they are 17x9x5. I tried everything I could to fit them on my S4 daily driver with rolled and pulled front fenders and they were still too wide. Granted it was with 255 tires but you can't* fit those wheels with a decent tire without major fender work. I run the wheels with a 15mm spacer now with 275 track tires on my OEM widebody A4 track car. They fir the A4 perfectly!!!
    My suggestion would be to go no wider then 8.5 in the front esp with those brakes that you have. Fitment will be very hard with your setup and desired width.
    97 A4 2.7T OEM RS4 Widebody 6-speed
    01 S4 2.7T Imola Avant 6-speed (Sold)
    90 Coupe Quatrro 20v (Sold)
    Feb 28 2007
    chicagoland
    the only reason your having issues fitting is the 255 tires.
    really i dont see it being an issue with 225s.
    whats the offset on your wheels?
    Nogaro 01 s4
    620whp 93octane
    Mar 22 2005
    FL
    Quote Originally Posted by Steve_Ag Arrow View Post
    Your A4 is secks
    Feb 27 2007
    Chicago
    Quote Originally Posted by JDM EJ1 95 View Post
    I would think they are around 32 or 35
    Feb 27 2007
    Chicago
    Your A4 is secks
    thanks!
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Fist of all you don't run a 225 tire on a 9 inch wheel...what's the point of going that wide of a rim with a skinny bike tire. It's true that Pat Lindsey's CCW's were 17x9.5. I have the same wheel but in size 17x9 (for sale in the classifieds actually). I run 245 series tires and without a doubt can fit a 255 on the car without fender pulling. If you want 17X9 that are designed to clear a Stoptech BBK PM me and I'll give you my full name. All CCW will do is search my name, get the specs and build you the rim. You have to run spacers without question for the front on a BBK and they build a spacer to accomodate that.
    Feb 14 2004
    Michigan
    Feb 28 2007
    chicagoland
    pic doesnt work^ (link)
    Nogaro 01 s4
    620whp 93octane
    Feb 28 2007
    chicagoland
    Quote Originally Posted by revhards4 View Post
    i dont track the car so im looking for mostly looks with the ccws... the s4 isnt made for turning. and a 9 inch wide wheel is 228mm which is just as big as a 225.. so its not a skinny bike tire as you would say.. it actually fits perfect as a 225.
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    Those wheels are going to look sick, good choice
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    225's are going to look goofy on a 9in wide wheel. Your wheel will poke but your tire is going to be stretched pretty hard.
    Just for fitment reasons heres a 225 on an 18 in wheel.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Thats Pat socals s4 befor the paint change. BTW he pulled the fenders on the black car...
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Quote Originally Posted by OldYella View Post
    lol vat?
    Feb 28 2007
    chicagoland
    ok and how wide is that wheel?
    so what i go 235.. its still nothign like a 255
    Nogaro 01 s4
    620whp 93octane
    Established Member Two Rings kodycobra's Avatar
    Jul 15 2008
    00S4,07 ZX14,05 AcuraTL,Z32tt
    Jefferson City, Missouri
    Just my opinion but... You need 245/45/18's, or 245/40/18's, depending on how much sidewall you want. The Less sidewall you have though, the worse the car will ride. Plus, for the price difference between the 225's to 245's... it's well worth it for more contact patch of rubber on the pavement. It's only a couple dollars a tire difference. If you lived closer, I could get you the major hook-up on tires, but since you don't... Try www.tirerack.com or www.discounttiredirect.com They have pretty reasonable prices.
    P.S. 245's are not considered wide either. I had 265/35/18's on an 18X9, and 315/35/18's on a 18X10 wheel... Now that's wide. That was on my Cobra though... Different class of car. Don't try it at home with an Audi lol
    Aug 18 2007
    Ohio
    Quote Originally Posted by unknowna4 View Post
    lol vat?
    Vat?
    2002 TT Silver 225
    Aug 18 2007
    Ohio
    Sorry forgot to put that those are 9in wide wheels.
    2002 TT Silver 225
    Oct 06 2005
    Soccer mom car
    South
    Stretch/Poke=Euro as hell. Do it! PS ccws, so hot.
    Feb 28 2007
    chicagoland
    i have a little plan for the ccws as well.. just gotta find someone to do it for me. :P hopefully i can get it the way i want it.
    i dont think those wheels up there^ that the strech looks bad at all.. its not a mega stretch.. i dont WANT to have to stretch like that but if i have to. its not a big deal.
    Nogaro 01 s4
    620whp 93octane
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Pats car was bad a$$ looking.. I really liked it, not so much now.. But function>looks I guess
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by kodycobra View Post
    This info is just going to cause problems. The sizes you mention are taller than stock which creates real fitment problems especially in the rear. The suspension upright curves up and over the top of the tire. I test fitted a well worn 275/40-17 and it would stick out nearly an inch more in the rear than in front because of the suspension upright. If the stock diameter is kept then inner upright clearance is fine and your only issues become outside clearance, spacing, and the changes in scrub radius. 225/40-18 is the correct diameter which means a 245/35-18 and 255/35-18 are both very close.
    This is the driver side rear with a 17x8 et35 and my 245/40-17 snow tires. Clearance is minimal at best and these don't even run wide for their size. To go even 1/4" taller would require spacing out about 1/2".
    Jim
    I Do Werk.
    Jul 15 2008
    Quote Originally Posted by onemoremile View Post
    Sorry, I forgot to mention that the 315/35's were on my Cobra, not my Audi!! I was just saying that 315's were wide, not 225's Edited my post to avoid confusion! I just don't like the "tires are too narrow for the wheels" look. I personally will be going with 245/35 /18's on my car
    Feb 28 2007
    chicagoland
    im thinking with my
    18x9 et 32 in the front
    18x9 et 27 in the rear
    and a 235/40/18 i shouldnt have issues.
    and the tire wont have a noticeable stretch.
    i might use a 5mm spacer if i need be to get the fitment i want.
    Nogaro 01 s4
    620whp 93octane
    Mar 09 2004
    nw michigan.
    The 275/40-17 is the Cobra's front tire. It runs a 335/35-17 in the rear. Superformance mkiii, RDI aluminum 427 small block, Tremec TKO 5MT, wilwoods, quaife, etc..
    I like the fatties too. That 245/40-17 shown above is one of my snow tires.
    http://s23.photobucket.com/albums/b3...t=IMG_4886.jpg
    http://s23.photobucket.com/albums/b3...t=IMG_4883.jpg
    Jim
    I Do Werk.
    May 10 2007
    CHICAGO
    what if someone tried to run a 19x11 on an audi hahaha that would just be crazy ...especially with a 25et... lol
    Feb 23 2005
    ccws, so hot.
    yes they are
    Dave
    Jul 15 2008
    Pure Sex^^^^^^^^^^^^^^^^^^^^
