Page 1 of 3 123 LastLast
Results 1 to 40 of 117
    Oct 06 2004
    Minnesota
    Lets get things started
    Well as some of you know, I am starting my build. After 150K of driving, 50K of that on T28, I am ready for an upgrade. I have been working with Issam and Jeff at 034 to create a build that will be strong, powerful, and reliable. As some of you know, I started a build about 2 years ago aquiring a 034 IIc standalone, some fueling components and other misc items. I ditched the project because I was not finished with school yada yada yada. Well, here I am, back just like I said I would.
    Plan is to keep it a 1.8 but make it rev :) 8200RPM will be the redline. My AEB head will be sent out for a re-build and to install the new springs and retainers. I am having Chris Tapp tweak one of his programs to fit my needs.
    Anyways, on with the goodies.
    Garrett GT3071R
    MAHLE pistons 8.5.1 CR
    Scat 144mm rods
    Eurospec main girtle kit
    SPA manifold
    Tial 38mm ex wastegate
    034 fuel rail
    034 fuel gauge
    034 FPR
    034 oil lines
    034 track density mounts
    630 cc Injectors
    Bosch 044 fuel pump
    034 FMIC
    Innovate wideband w/ gauge
    Custom Downpipe
    OEM gaskets (new)
    OEM oil pump (new)
    Raceware hardware
    Vortex Catch Can
    High Rate Valve spring set
    Titanium retainers
    Pics are more fun:
    upside down lol
    I also picked up a spare AEB motor to start the build on. Someone buy my T28 kit! Argggghhh
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Lets get things started
    still running standalone rob?
    Oct 06 2004
    Minnesota
    Quote Originally Posted by 317ssayzarc View Post
    Never was. I had it but never put it in. I will be running a tweaked CTapp file.
    Instagram r_michals
    Oct 27 2007
    In the lab
    Quote Originally Posted by A4Rob View Post
    tweaked as in...?
    Oct 06 2004
    Minnesota
    More boost, higher redline.
    Instagram r_michals
    Oct 27 2007
    In the lab
    i HIGHLY reccomend NOT running the boost via n75... and i hope that 3071 doesnt run out up top, im pretty sure mine will
    Oct 06 2004
    Minnesota
    My car has not seen a N75 in over 3 years.
    Instagram r_michals
    Oct 27 2007
    In the lab
    oh good! well the file is MAF based so i doesnt need tweaks for higher boost unless you really want to drop the timing to add boost... that method doesnt produce the best numbers and you shouldnt need to retard timing with your CR anyways... so whats he tweaking besides the redline?
    Oct 06 2004
    Minnesota
    Thats pretty much it. Any BAT should make good numbers revving it up. Nothing spectacular. There are probably 20 cars running around with the 3071 + ctapp. I am just running more boost and rev. Hoping for good numbers.
    Instagram r_michals
    Oct 27 2007
    In the lab
    Me too, hopefully you have better luck than me with Tapp
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Holy crap how wide is that TIP? Lol looks like a horse's... well... you know...
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Oct 27 2007
    In the lab
    Quote Originally Posted by sixfiveoh View Post
    4" my friend , bout how long you are
    Oct 06 2004
    Minnesota
    Makes me want to go uni after reading your thread. Software is the only thing I still need to purchase.
    Instagram r_michals
    Oct 27 2007
    In the lab
    There is no good narrowband tunes for me imo... your setup is fairly generic, mind is far from that... you will have no problems with tapp, he is the best me5 tuner imo, uni the best me7 tuner... i have the 3071r file with 93 and meth tunes on it if you are interested
    Oct 06 2004
    Minnesota
    PMing Jake
    Instagram r_michals
    Oct 06 2004
    Minnesota
    UPDATE:
    PES T28 is out. Wow that was a PITA. SPA manifold is on. Turbo is on. I am awaiting my FMIC from 034 and also the V-band clamp kit so I can get started on my downpipe. Monday I plan to make some oil and water lines for the turbo. We have a few stores around town with all the AN fittings I will need. I also installed the 034 fuel gauge. Neato. It is fun seeing this all come together!
    Also painted the bay black finally. I have been a real lazy slob.
    Yes my valve cover is purple.
    Instagram r_michals
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Engine is already built?
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by nebone22 View Post
    Wondering the same thing, if so that was pretty quick!
    Oct 27 2007
    In the lab
    Rob, the ecu, maf and pigtail harness are in the mail... Also I forgot to tell you youd need the metal maf adapter flange to run a 4" filter off of it, so I put that in too... Also included a wire chart for which color goes to which color on my 98.5 AEB, I told Arnold I had an AEB and he sent me that, so I think it shoudl work for you too ... All was carefully packaged up and sent to you yesterday, let me know when you get it!
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by big_greasy_taco View Post
    x3
    Oct 06 2004
    Minnesota
    No, Sorry I should have been more clear. I have not started building it yet. Reason I pulled my T28 off is because I have a buyer for it and he wants it on his car soon. I installed the 3071 while I build my other motor. I plan for that motor to be finished in about a month or so.
    Instagram r_michals
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    gonna watch this very closely. I was considering a build like this since i didnt want to go 2.0....too bad i gotta fix other probelsm on my car first :(
    sounds like lots of fun though!
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    May 11 2004
    minneapolis
    Hey Rob,
    I've got some AN stuff laying around if you are interested. It won't be everything you need, but I'll give you a good price on it. Shoot me an email.
    Oct 06 2004
    Minnesota
    PM sent.
    Thanks a lot Samx
    Instagram r_michals
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    lose that gold crank pulley
    looking good!
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Looks good Rob should be fun!
    Feb 27 2005
    North Wales, PA
    your lighting set up is sweet
    Oct 06 2004
    Minnesota
    3 days and the turbo setup is finished. I spent a lot of time figuring out how to make all the lines. That sucked but it was a good learning experience.
    Chris Tapp intake setup (for search results)
    Making the downpipe
    Right now my vacuum lines are completely tangled in a mess. I am going to re-route them tomorrow so the car actually runs. Catch can and the wideband will also go in.
    It was a LONG day. I am off to bed. VIDEO coming soon!
    Instagram r_michals
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    cool. gogo diverter valves
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Nice build!
    Love the purple...
    Do you rub your junk against that picture when working out? Not that I'm judging anyone or anything...
    http://img.photobucket.com/albums/v4...m/IMG_2794.jpg
    Jim
    I Do Werk.
    Sep 24 2005
    always in design
    Looking good Rob, I would coat the Manifold if you get the chance with Swaintech.
    Registered Member Two Rings a220vt's Avatar
    Dec 03 2006
    '97 A4TQMS, '97 GTI
    Broomfield, CO
    Looking good, how did you add that port to the silicone hose for the diverter valve? Also, the lightning MAF likes to have as much straight section before and after the sensor as possible to avoid turbulence. Just something to think about, I went through probably 4 intake setups before I got a car that ran right and wouldn't stall out all the time.
    Don't talk about it, be about it......
    Oct 06 2004
    Minnesota
    Quote Originally Posted by onemoremile View Post
    Nice build!
    Love the purple...
    Me working out? haha no
    Quote Originally Posted by bassed View Post
    Thanks for the advice. I will do that tomorrow
    Quote Originally Posted by a220vt View Post
    Hmm that makes sense. I am having some issues with the car stalling right now. Do you have a pic of your setup? Is it in one of the tapp intake threads?
    Instagram r_michals
    Oct 06 2004
    Minnesota
    Just got back from a trip. The car is not boosting properly. Could it be because of not running the 2nd O2 sensor? The car drives fine, but hesitates to build any boost. It almost seems like my plugs could be fouled out. My Innovate wideband is not installed yet.
    Does anyone have any other ideas? My first thought was a boost leak. Hmmm?
    Instagram r_michals
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    install your wideband
    ::2002 S6
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by TQMB5 View Post
    x2
    Dec 03 2006
    '97 A4TQMS, '97 GTI
    Broomfield, CO
    Here's some not very good pics of my intake setup, I had a different manifold than you though. It's kind of hard to tell in the photos, but the intake goes: airfilter, adapter, maf, steel reducer welded to 90 degree bend. I also found that running the DV port at an angle in the same direction as airflow really helped with driveability as well.
    How did you put that hose port for your DV in the silicone hose?
    As far as your boosting issue, did you remember to put the fire ring in the wastegate?
    Oct 27 2007
    In the lab
    what are you using for boost control Rob?
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    Rob, you HAVE to make that inlet longer and wrap up under the frame, or something along those lines. the MAF is way too close to the turbo and the car will most like idle/part throttle like poo.
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Oct 06 2004
    Minnesota
    Took a plastic PVC adapter used for household plumbing and ported it through. Air sealed it with silicon. Ghetto, but it works.
    I got my wastegate through the vortex classifieds, so I have no idea. I will pull it off tomorrow and take a look at it.
    Piggie MBC. Pretty much the brass ones you can make at the hardware store. I have it on the same setting as my T28 setup had.
    Quote Originally Posted by bernB5 View Post
    Thanks for the input. I will play around with other options. Right now I am using a ITG foam filter and it is literally about .5" from hitting my AC belt just next to the condenser. I will take a picture tomorrow from under the car looking up.
    Once again, thanks everyone for your advice and input.
    Instagram r_michals
