Can someone review the values I am using the map out the efficiency of my turbo? I want to make sure they are correct.
Here is the info regarding how I am getting some of these numbers:
Turbo: The disco potato (GT2860RS)
Intercooler: EvoMS FMIC (Normally looking at 1.5 to 2 psi of pressure drop)
Chem. Cooling: Methanol/water injection (thus the lower than normal intake temp number)
BOOST(PSI)...............20
DISPLACEMENT(cc).........1781
INTAKE TEMP..............90
VOLUMETRIC EFFICIENCY....90%
COMP. INTAKE TEMP........545
COMP. INTAKE PRESS.......18.98
IC PRESSURE DROP(PSI)....2
By my calculations, I am completely out of effeciency at 20 PSI above 5.5k RPM which seems odd to me. With only 18 PSI I about 70+% across the board.
