Results 1 to 6 of 6
    Apr 10 2008
    jakarta
    [Ask] if i change the brakes, does it affects the ESP ?
    Hello,
    i have planned to substitute my front stock brakes into a Brembo 4 pot brakes. Does it affects the ABS/ESP ? need help :)
    thanks..
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Re: [Ask] if i change the brakes, does it affects the ESP ?
    You will have no issue.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Apr 10 2008
    jakarta
    sorry, you mean it wont affects the ESP/ABS ? wheres the sensor of ESP/ABS ?
    DUH! an Audi
    los angeles, CA
    no it will not, just make sure your pads have sensors so you can connect the pad warning.
    Apr 10 2008
    jakarta
    thanks boss !
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    I hope your getting in on the GB I have then ;)
