Results 1 to 8 of 8
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    added too much oil? am i at risk?
    added only 4Q of oil at my last oil change just to be safe, but dipstick level is past the shade area, right about at the the 90deg bend. maybe the old oil didn't fully drain out?
    put 2K miles on the car since then. runs fine, but have i done any serious long term (cat) damage? should i drain/pump some oil out? what is the best way to do this?
    thanks.
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    Re: added too much oil? am i at risk?
    Here's an earlier thread with advice on this:
    http://www.audizine.com/forum/showthread.php?t=226994
    Hope that helps.
    Apr 17 2008
    Chapel Hill, NC
    Quote Originally Posted by Teratorn View Post
    Hope that helps.
    thanks for the info.
    i actually did read that thread, and i searched 3 different times. sorry to start a new thread. , but i guess what i meant to ask was:
    how can you tell if you have damaged your catalytic converter?
    meanwhile, im gonna start drainin'....
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Didn't some guy just post about using 7Quarts with his last change? I'm kind of confused, how much should people be putting in?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Jul 11 2007
    Lakewood Cali
    Quote Originally Posted by Exanimas View Post
    it has to do with what size motor you have. the 3.0's im assuming use somewhere around 7 i have a 1.8T and use somewhere around 4ish
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by sixty40band View Post
    You are correct and I am a tard. Thanks for clearing that up. I just got nervous because when I had the oil on my old car changed I read like 3 different amounts in 3 different places, and they ended up overfilling it.
    -Nick
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    having to much oil in the crankcase is not good. it will cause uneeded stress on the oil pump and o-rings. So when you increase the oil level, the bearings are submerged in oil. When the bearings swirl it works like an egg beater and it causes the oil to foam which leads to vicosity breakdown.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    3.0 motors are 6.6 quarts
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
