After a little search on google, here is how to use Auto-RX on our engines (
http://auto-rx.com/pages/applications.htm):
"First change your motor oil and filter. Add one full 12 oz bottle of Auto-Rx® to your engine.
Auto-Rx® works best with conventional (non-synthetic) motor oil. If you feel you must use a synthetic motor oil we recommend using a Group III oil to avoid competing chemistries.
At 2,500 miles change your oil and filter again, but do not add Auto-Rx® or any other additive. Drive an additional 3,000 miles, then change your oil and filter again.
You may follow up your first application with a second if you feel additional cleaning is needed. Vehicles with over 100,000 miles require a second application.
We recommend that you follow up your treatment by going on the Auto-Rx® Maintenance Plan. This will ensure a clean motor and maintain peak performance."
Its pretty straightforward, except for the part where they mention to use Group III oil. On another thread, CO AVANT used castrol gtx 5w-30 oil for his Auto-rx treatment, and you have to drive 2500 miles with that, which I am not sure if we should do so. And for people who do a lot of stop and go (like me) and not much mileage, I think the 2500 number should be much less. Like I mentioned I only drive about 5000 miles a year, and thats a lot of stop and go on a daily basis. Any comments?
