Results 1 to 9 of 9
    Mar 04 2007
    dealer TSB flash and apr program
    Went to the stealership today and they flashed my ecu with some sort of tsb program. I went in the stealership with my lockout program. For the people that had their apr program erased by the dealer tsb flashes were you still able to access the apr flip switch like going to stock to octane 91,93 or did it simply not allow you to switch anymore? How do you know if your program has been erased? I'm asking because I'm still able to do the flip switch via the check engine thing but I cant really tell the difference between stock and 93. Maybe I'm so use to octane 93 that I cant tell anymore.
    Sep 15 2005
    Norwalk, CA
    Re: dealer TSB flash and apr program
    if your chip is erased, you shouldn't be able to switch it anymore. It sounds like the dealer didn't really perform the update on your car.
    Peter
    Nov 12 2007
    Grand Junction, CO
    if you can't feel a difference.....it's probably been flashed over. Trying going to your APR dealer and see if they can tell you.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    if you can control the switching with your stalk for the different programs you have, then the dealership never reflashed you correctly.
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by AudiWxGuy View Post
    Not true. The difference between 93 chipped mode and stock is HUGE. Any time I drive my car in stock mode it is very very apparent.
    I'd say if your car feels the same as it did when you dropped it off, you haven't been flashed. Why you cant feel a difference between stock and 93 I have no answer for. Are you sure you're switching programs correctly?
    Mar 04 2007
    Well I do feel a little difference between the programs so I guess I still have it. Not a HUGE difference though. Like I said I must be use to the power.
    Whenever our cars gets reflashed with a tsb from the dealer, does it automatically take out the chip? I think I'm just paranoid. I'm gonna go to apr to have it checked to see if it is still there.
    Jul 20 2008
    Chicago
    Quote Originally Posted by denisk View Post
    With my REVO, yes it gets over-written by the dealer if they do a TSB repair requiring it, according to my REVO dealer. With APR I heard this is also the case. It seems logically true because it is similar to the wiping of a hard drive in the PC world rather than just changing/upgrading the operating system (where our flashed ECMs would be the same as having a resident program loaded on a computer's hard drive). Even though the ECMs are solid state, they can still be wiped clean.
    One other issue with REVO (not sure with APR) is that if I disconnect the battery for whatever reason, my REVO flash isn't erased but it does become disabled unless I have the Select-Plus tool option whereby I can, I'm told, re-activate the program...NOT reflash the ECM, just enable the flashed program to run after a power interruption.
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by Bmeister View Post
    You're absolutely right. However, I don't think the issue is whether or not it is possible for your aftermarket flash to be flashed over but whether or not the dealer performed that particular service.
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I have 93 APR and it's a HUGE difference between it and stock. I mean it's like a short fat girl compared to a tall thin blonde, it's really night and day for me.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
