    Jul 19 2008
    MIlwaukee, WI
    Arrows on pistons (stupid question)
    put my stock Aeb pistons back in on scat rods and forgot if the arrow on the piston went towards the front of the motor or the back....they are in facing the front now because this is what i thought i remembered...let me know
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: Arrows on pistons (stupid question)
    what arrows, you mean the small indentatios on the outer diameter surface? of so those go towards the oil cooler, meaning towards the driver`s side.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    you can kinda see the arrows there...
    the arrows go towards the front... its pretty obvious since the indent on the perimeter is for the center intake valve lol... but on a more serious note, you really should have marked or noted everything before or as you took it apart...
    Jul 19 2008
    MIlwaukee, WI
    i did mark all the pistons 1 2 3 4 and marked everything else on a pad of paper like im supposed too, all my bolt are in individual bags marked where and position they go. I just somehow forgot to mark that for the pistons...anyways i installed them right just sometimes my memory sorts and i didn't want it to happen again, but i figured it was for the intake valve in the center. Just had to make a tool to get my retainer clips back in on the valve and just got it done ready to install head...im pumped to get this thing running
    Jan 24 2007
    i'm sure that is to just tell you the direction that it suppose to go. Also it should be facing toward forward
