    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Did I find my problem yet? What should knock sensor V's be around?
    What should the knock sensor voltages be around when driving part throttle... Because mine look like such...
    Cyl 1 - 1.5-3.0V
    Cyl 2 - 3.5-5.0V
    Cyl 3 - 1.5-3.0V
    Cyl 4 - 1.5-3.0V
    As you can tell, cylinder 2 is pretty high... Also, the other day, I had a MISFIRE at cold start... I am also getting random knocking.... I am assuming it is cylinder 2... I seafoamed it and made no difference... I mean, this knock is enough to ECHO off the walls of the buildings around me... Mainly when I shift or let off the throttle at mid-high rpms.... Sometimes happens at part throttle when in gear but mostly when I go to shift... I also see up to 4 or so just driving around on block 020 when all others are 0... So now, I am thinking maybe we are getting somewhere and it is NOT my ECU causing my low boost request issues... So, the knock sensor isn't bad since everything is pointing to cyl 2 and I am getting actual knock... No CEL either...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Re: Did I find my problem yet? What should knock sensor V's be around?
    So then, I take it you determined that your fuel pressure was okay? What do your spark plugs look like? Take pictures of them and post them up if you can; preferrably labelling which plug came from which cylinder...
    "You know you have a bad idea when Ford guys are making fun of you."
    Mar 04 2007
    nothing
    nowhere
    I just changed the plugs like two-three weeks ago... The ones that came out were fine... The issue has been lasting as long as the low boost issue but I just now plopped acrossed it again today because it was acting REALLY bad...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    at idle my knock sensor voltages are <1, part throttle they are around 1-4 (depends what you mean by part throttle) full throttle My knock sensor voltages are around 15-20V idk if this is helpful because i dont know if mine are okay or not...
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Cyl 2 is always higher, its a 1.8T block design. Any 1.8T car will have a higher voltage reading on cyl 2. Also, it is hard to determine what knock voltage really means. I hit my max allowable before tho which is like 29 IIRC. What you need to check is your timing retard to look for problems.
    I always get timing retard of 4-6 just coasting/driving around. I have a new cam chain tensioner in now so that could possibly change timing retard.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
