when i blew my gt 28rs years ago i went with a gt3076 wg from atp. it uses a v-band adapter. now the adapter is leaking [ prob warped] the problem is, i want to go with a new exhaust side [ non internal gate] it seems atp uses a custom exhaust side and a different trim wheel for the internaly gated turbos[ the wg is a totaly different turbo than the standard 3076]. i had the internal gate removed, i tapped the wg hole and pluged it. now i run an external tial 38 mm wg. my problem is i need a new exhaust housing with a v-band built into the housing and i cant find one. what have any of you done to run an external gate after you got the internally gate turbo. sorry for the ramble, i still need to wake up. i need to get this ordered asap as my current setup has a wicked exhaust leak
