Results 1 to 2 of 2
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Uneven ride height in front
    So I installed my new control arms on the driver side and had a shop do the passenger side. Now my driver's side is sitting about a finger higher than my passenger side and I'm trying to figure out why. When I did the driver's side, I removed the whole strut mount via the bolts in the engine bay. There is a little play to the positioning of this mount bracket as the holes are larger than the bolts. Could it be at a slightly different angle, causing a higher ride height? My other guess is that the control arms are torqued down differently. When I torqued down the driver side arms, I used a hydraulic jack and jacked the suspension up; however, I just estimated about where it would be.. I didn't do it with the wheel on. For that matter, I don't see how you could torque down anything with the wheel on... I could barely torque things down with the wheel off and the car raised high on jack stands.
    The obvious unknown variable here is that I don't know how the shop did the work. I'd like to figure this out before I get it aligned because I'm thinking any future correction of it could potentially throw the alignment off.
    By the way I'm lowered on H&R sport springs and Bilstein struts.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    May 30 2004
    1997 1.8TQM
    Re: Uneven ride height in front
    bump!
