Results 1 to 4 of 4
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    someone help...if u know about rims..please
    i am highly considering buying EXE rims can i get like a quality check on these??? anything i should know ..thanks for the help
    Wheel model: EXE Konvex by AXIS
    Wheel Diameter : 19"
    Wheel Width: 8.5" Front and 9.5" Rear
    Lip Width: 2.5" Front 4.0" Rear
    Wheel Offset: ET30 Front and ET40 Rear
    Wheel Finish: Diamond Cut with High Polished Lip
    Aug 01 2008
    forked river, NJ
    Re: someone help...if u know about rims..please
    pretty pretty please
    Jul 21 2005
    '99.5 A4 APR Stage 3+
    Alabama
    I've never heard any bad reports about AXIS wheels. The only thing I'd be careful of is trying to run staggered wheels on a quattro car. It's been debated many times on the forums the danger of running different size tires front to rear. Although it may not be much, your front tires will either be shorter are taller than the rears. So, for every revolution the taller tires travel a farther difference. If the vehicle were two wheel drive this wouldn't be a problem but because of the interdependance of all wheels this will create somewhat of a bind somewhere. How much? I don't know. What size tires are yuou thinking about?
    Feb 13 2008
    you should know that you'll want the whole WHEEL and not just the rim.
