We are pleased to announce that we now carry the Vac N Blow vacuum cleaners.
Here is a description:
Metro Vac 'N' Blow
This twin fan 4 peak horsepower vacuum is the most powerful car vacuum ever tested. It has an amazing 95" of water lift (the standard measure for a vacuum's efficiency). Compact, powerful, portable, it's heavy-duty lightweight all-steel body is only 17" long and 7" in diameter which makes it easy to handle. Use it off road, too, as a vacuum for cleaning around the house or yard, or as a blower to inflate rafts, air mattresses or blow away leaves. On road or off, Vac N Blo® offers the versatility you need. It comes fully equipped with a wide range of attachments, so whether the job calls for power or precision, you'll have the right tool at hand. A 6 ft flexible hose plus two 20" extensions reach even the furthest corners. Other attachments include: an upholstery tool, dust brush, crevice tool, blower nozzle, air mattress inflator, shoulder strap plus 4 "detailing" attachments to get into tiny spaces.
Vac'N Blo Features:
- Construction: All Steel, Made in USA
- Motor: 4.0 HP, 95" Lift
- Volts: 120 V, 11 amps, 12 ft. Extension Cord
- Decibels: 73-77
- Hose: 6 ft. Flexible Hose, (2) 20" Extensions
- Filter: Reusable Dust Cloth Bag
- Attachments: Upholstery Tool, Dust Brush, Crevice Tool, Blower Nozzle, Air Mattress Inflator, Shoulder Strap, 4) Mini "Detailing" Attachments.
- Warranty: One Year
Item ships only via UPS Ground
Click here to purchase
