Results 1 to 36 of 36
    Registered Member Two Rings ben light's Avatar
    May 26 2008
    2003 Audi A4, 2007 Mini Cooper
    Dover pa
    Carbonio intake???
    Has anyone put a Carbonio intake on their 1.8T??? If so, are you happy with it and is it worth 379.00???
    Jun 23 2008
    Re: Carbonio intake???
    I've been contemplating on getting one myself, since as far as I know this is the only aftermarket one that comes with a heatshield to protect it from turbo heat(correct me if i'm wrong.) Although I have read in 1-2 other forums aside from Audizine that the stock intake on the A4 is sufficient enough.
    On Audiworld.com I came upon a B6 Project car which installed a Carbonio intake system. "It looks to us like intake temps decreased on average about eight degrees, which translates into a significant power increase and associated better throttle response. Besides the performance, the look of the unit is quite impressive." This is a picture of the graph of the Carbonio intake results.
    http://www.audiworld.com/news/08/pro...-4/header5.jpg
    This is just some information I have found in my research of aftermarket intakes for my 2004 A4, hope this helps.
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    they show up in the classifieds every once in a while. i dont think i could justify buying a new one for limited at best increases in performance
    May 26 2008
    Dover pa
    Thanks guys. I do agree, it does look awesome. Still not sure though.
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2006 VW Touareg (on blocks in my driveway). 2007 a4 2.0. 2003 a4 1.8tqm sport (sold)
    Ummm the Jersey Shore
    I have one but my car has no other performance mods yet. Other than the sound of the diverter valve between shifts and looking nice in the engine bay, I don't believe it did much if anything at all for the performance. The intake itself is not loud like you would expect from hearing on other cars. You definitely hear your turbo spool louder and the dv between shifts. I'd try to get it used if you can find it. Fitment kinda sucked but once you get it in there it looks good.
    Miss my B6
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    it doesn't do much on stock but flashed it may benfit a bit more. I got mine free so i have no complaints but i don't think i would buy it. They show up in the classified frequently anyways or just make a custom one instead
    CT4952
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    I've had one for about 8 months now. There's no performance increase from it that I can feel but you can definitely hear the diverter valve better. I got it for Christmas so I think it was worth recieving as a present atleast! And it looks swweet!
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    I've been running the Carbonio intake for over 2 years and I like it. It looks good, sounds great, and improves the throttle response a little. However, it's an expensive mod and won't increase the power of your car THAT much. If you have the $$$ and want one of the best intake for our A4, go for it!!!
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Looks good and sounds awesome but thats about it. No power gains...but I still don't regret the purchase and I'd buy it again.
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Im looking to sell/trade mine for a stock intake plus cash. Anyone interested lmk.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    If you have the cash and love popping the hood, then I would get it.
    It def looks schweeeeet!
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    When mine got installed I notice better throttle response and a slight increase in mpg. In my B5, I used to get 330-350miles to the tank, now I'm getting at least 340 each tank.
    TEAM|AXION
    Could be.. But also could be you sub consciously driving slower and not even noticing it.. Or earlier shifts.. Or GRKa4 sneaking over to your house and adding gas to your tank to throw you off.. C'mon who knows nowadays, its 2008!
    May 26 2008
    Dover pa
    Thanks for your help guys. I think I may get one. I don't really have anything done for show under the hood yet. I am getting my engine cover and all the fluid caps painted to match the car. I do have the bigger fuel injectors, GIAC flash, Forge DV and Magnaflow exhaust.
    Jan 10 2007
    VA
    My exact thoughts. (I didn't want some cheap looking DIY intake, I wanted something subtle and nice...Carbonio certainly lived up to that)
    Quote Originally Posted by quattrotman View Post
    May 26 2008
    Dover pa
    I agree. I think I am ordering it today. Thanks guys for all your input!
    _____________________________________________
    2003 Audi A4
    Giac Flash, FX Fuel Injectors, Forge DV, Magnaflow Exhaust, Carbonio intake, Eibach lowering springs, Color matched Mille Miglia 18" wheels, Vizage front lip, Erebuni wing and grill, Full Sherwood dash kit, AWE pedals, a little bump in the trunk.
    www.cepavw.org
    we roll deeper
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    It'll look good until it yellows... unless they fixed that problem... also ben_light, saw your car at Vag Fair... very nice and what color purple is it.. IIRC
    May 26 2008
    Dover pa
    Thanks man!!! It is actually Ming Blue.
    2003 Audi A4
    www.cepavw.org
    we roll deeper
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Your welcome, I posted a pic of it in the Mid Atlantic forum form the show.. then that is the first Ming Blue I have seen in person.. nice color...
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I have it. It's flashy because of the CF lid. You get a "woosh" that makes the DV sound a little like a BOV. There may be a little more air flow, but nothing that makes any substantial gain. From all tests done with Carbonio and others, you can't beat the OEM air box.
    USP CLUB MEMBER #34
    Jun 17 2007
    I spoke to Apr at waterfest and they are aware of the yellowing. I have to take pics and contact apr one of these days. They will replace the cover if it yellows from what I am told..
    Miss my B6
    Jan 10 2007
    VA
    ^ yep. my first lid yellow-ed and hazed up within a month. it was replaced free of charge and the new lid still looks good after 18 months of use. i was told they had a bad batch.
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Quote Originally Posted by pondside36 View Post
    why does everybody call ming purple. You don't know how many times chicks have said "oh I love this purple color", it drives me insane................
    I just ordered a new carbonio when they were doing the 15% off sale but with tax and shipping it still came to 380.
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Veteran Member Four Rings osofast10's Avatar
    Dec 26 2004
    02 Audi A4 1.8t
    woodbridge, Va
    i have Ver. 1 and i love it... wish i could have Ver. 2 but for now i'm super happy with it and the fitment was great for me
    1996 2.8 Audi A4 -> RIP
    2002 1.8T Audi A4 -> SOLD
    2005 Toyota Prius -> DD
    2010 Acura RDX --> DD
    Established Member Two Rings kerlow66's Avatar
    Jun 26 2007
    02 S2000,05 V8 touareg,Duc749s
    los angeles
    $379.00 for a intake?its not worth it.Just get a chip and youd be smiling in no time.
    Established Member Two Rings utripn's Avatar
    Jul 13 2007
    2006 Audi A6 4.2 S-line
    Mission Viejo
    the carbonio wont fit the nuespeed extreme TIP, just FYI, i had a carbonio intake and i had to go back to the stock intake because i bought the nuespeed extreme TIP and the hose did not align to the filter housing, oh well, i think stock is better plus the swoosh noise will get on your nerves after a while.
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    I've had mine for over a year now and love it. It works great for adding good looks to the engine bay and also for hearing the DV. Mine was a gift too so that's even better. I don't think I could justify the price otherwise. I still love it though
    WTB K04 turbo ASAP
    http://etektuning.com
    Feb 06 2008
    03 a4 tip
    CAL, PA
    I have had the carbonio for about a year. Its sexy and makes the dv sound louder. You can also hear the air rushing into the intake when you are just cruising around. I am happy with it. No yellowing or discoloration. Great product.
    z
    Feb 23 2004
    Stow, OH
    Mine's been turning a greenish yellow color. APR won't replace it. They say that if you use cleaning/detailing products, it voids the warranty.
    USP CLUB MEMBER #34
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    well if you get it at whatever price, do some kind of heat wrap to keep the intake temp cooler.
    contact rxrep is you need
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    May 26 2008
    Dover pa
    Thanks again for all your input. I received it today. Prob won't get a chance to put it on until the weekend.
    2003 Audi A4
    www.cepavw.org
    we roll deeper
    Jul 11 2008
    Illinois
    Oooh man, the installation was just plain stupid. Maybe it was just me but it took me about 3 hours to get it put together and make it fit. Juat the fitting probably took about an hour.
    Anthony
    Jun 23 2008
    Quote Originally Posted by GTRS A4 View Post
    Ive heard alot of install problems with this unit, I don't get why Carbonio would design a product for a certain application but then make it a btich to install... don't these people test fit things or is it just me? In the end, i'll probaly still get one. Yes, i'm now a hypocrite.
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    I'm doing a DIY cone in about a week for the sound thats all.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Three Rings dchan189's Avatar
    Jul 20 2008
    2004 Audi a4 1.8T Quattro USP
    San Diego
    does anyone have any pics of it in?
    Jun 08 2008
    Calgary AB Canada
