Results 1 to 20 of 20
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    Question Small problem turning BIG!?
    so as some might remember, i posted the other day that my 30v 2.8 was expiriencing some fluctuations in the coolant temp readout.
    as i wait for my new coolant temp sensor to arrive, the problem seems to have worsened.
    as of today, my car doesnt just run a little bit hot, it runs hotter and hotter the longer the car is running...so much so that i saw the temp warning light come on twice on my way home from work.
    one other thing that i am noticing is that when the temp guage goes about 3/4, my oil temp goes up a bit into the 250 range.
    i am hoping that this coolant temp sensor will solve all but these new problems are scaring me...BTW i do have coolant in the car and have no other ideas as to why this is happening
    any hints or advice?
    link to previous thread http://www.audizine.com/forum/showthread.php?t=227553
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Small problem turning BIG!?
    What color is your coolant?
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    green...
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Did you put in the green coolant or was it green when you bought it?
    Why I ask is, I ran into problems similar to yours because the PO didn't flush the OE G12 before filling it with green coolant. A complete coolant flush got rid of my problems.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Oh by the way, the original coolant is pink.
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    car has had green coolant since ive owned it, which is about 5 years now
    cant hurt to try flushing to coolant tho
    any other opinions?
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Try flushing the coolant.
    The way I did it was flush all the crap coolant out and then run a couple gallons of distilled water through it and drain it again. Then add G12 or the green stuff.
    Jan 24 2007
    I'm guessing your fan is not kicking in??? If anything turn on the a/c so that both fan's are running this should help little bit to cool down the car.
    Yes go get yourself G12+ and change your coolant
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    since your oil temps are rising, I would say the engine actually is running too hot.
    Does the coolant temp ever get too high when driving at freeway speeds? If it still does, its not the fans.
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    BTW i have to run my car with the heater on FULL or else it would just keeping heating up and showing temp warning light...if that helps with diagnostic
    May 22 2008
    is full of crap
    sandville
    The heaters like a little radiator and helps draw heat away from the engine. That tells me most likely your water pump is doing its job.
    Now what about on the freeway < please see my earlier post.....
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by EUROchop View Post
    BTW i has to run my car with the heater on FULL or else it would just keeping heating up and showing temp warning light...if that helps with diagnostic
    I can't stop laughing.
    Wtf? When was the last time you changed your thermostat?
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    Quote Originally Posted by MattzWarsteiner View Post
    fans are working fine, car heats up on freeway more than i noticed on the road.
    Previous owner "supposedly" had thermostat changed at 80k, pushing almost 130xxx now
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Matt called it.
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    Quote Originally Posted by ILoveT View Post
    i just got why you posted this pic, and it is hillarious lol
    I has edited post
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Hahaha!
    If it is heating up on the highway that means no coolant is flowing so it can't be cooled off. Since no coolant is flowing your water pizzump may be baaad. Or sludged up because of a mix of 2 coolants. Flush it first because that is the cheapest option, like $10. If that doesn't fix it, water PUMP!
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Hahaha!
    Let's just clarify that G12 is more like $24. Honestly, I doubt there is any real reason to run G12 but I'd rather be a sucker and not have to worry about it.
    I have to fix my dad's A4 because he mixed coolants and it's sludged. We were thinking it's the thermostat but maybe it's just sludge? I think I may just replace his Tstat anyways because it's only $20.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    i was hoping it might not be the water pump but ill try flushing the coolant first and see what happens...
    i know im supposed to use 1 part coolant per 1 part water, but how much of each does that equal to?
    Dec 21 2006
    98.5 A4 2.8q
    BPT, CT
    Quote Originally Posted by matt719 View Post
    ive read there is a place to find G12 for $25 a gallon, anyone know where?
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I never said to run G12. You can run straight water....
