    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Emission/ Exhaust Questions
    I have an A6, but i'm always on here and this forum get much more traffic.
    Anyway, I failed the emissions test with me 2002 A6 3.0 due to a broken flew pipe, aka exhaust leak.
    The full piece which includes one cat, the downpipe portion, and the flex pipe from audi is over a grand for one side. Which as we all know is ridiculous. One of my old bosses, who owns a shop said he can fix it with oem parts for about 550 parts alone. He does things 100% by the book, no ghetto rigging it.
    ECS and any exhaust shop should have a generic flex pipe section that they can weld/clamp in right? I mean do i really need to do it with oem stuff? Keep in mind i'm selling the car and only need to to pass inspection once and then it can be someone else's headache.
    Realistically, a $40 flex section and a couple clamps and my angle grinder to cut the piece out should do the job? or no?
    Thanks in advance guys!
    Awaiting Confirmation Two Rings
    May 24 2008
    2003 Audi A4 3.0 Quattro, 2008
    Semi-lovely Bradford, Vermont
    Re: Emission/ Exhaust Questions
    Flex-pipe and a pair of clamps will probably get you a sticker, provided the pipe either side of the flex on it now is solid. A bead of weld on each end would be even better. Neither of these will be a good choice for the long term.
    Regards, Dean
    Feb 17 2005
    Sarasota, FL
    Is the leak for sure at the flex section? If so a new flex joint can be bought here
    http://www.atpturbo.com/Merchant2/me...egory_Code=FLX
    Jul 06 2007
    Bremerton, WA
    well ecs has these, think it should work for a couple months?
    http://www.ecstuning.com/stage/edpd/...tegory=Exhaust
    bottom of the page...
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by thebikedoctor33 View Post
    Yes but more money than the SS ATP versions ...
