Results 1 to 8 of 8
    Dec 01 2007
    Orange County, NY 10918
    Brakes and suspension????
    Currently looking for new brake setup and suspension for my car. 2003 Avant TQM. got 19" TSW.
    What to get?????
    I want bigger brakes but cant afford a big brake setup. Was looking into the 3.0 carrier and rotor setup-- is it good?
    And what do i do for the rears?
    And for suspension-- looking at springs and then some bilstiens. Which ones to buy. Bilstien HD, Bilstien Sports, confused
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jun 14 2005
    Anaheim, CA
    Re: Brakes and suspension????
    Ever thought of getting a more aggressive pad rather then a BBK?
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Dec 01 2007
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    www.vmrwheels.com
    yeah have thought of that. But looking to fill up that 19" wheel with a little bigger setup.
    ECS has the carrier for my car for $140 each. just need rotors and pads?
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Mar 27 2005
    The Cold North
    the size difference between the 1.8T & the 3.0L rotor isn't much. Your still not going to fill up your 19's.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Registered Member Two Rings
    Sep 25 2007
    Santa Fe, New Mexico
    I upgraded the rear with 305mm and they look about the same as the fronts. Looks and brakes much better. Putting B7 S4 brakes on the front, 345mm.
    2004 A4 Quattro 1.8T USP 6MT (white) XM, Ipod
    35% tint, AT Italia Spider wheels, BFG KDW 2, 235 40 18, K & N, RS4 Rear Sway bar, STaSIS Alcon rear brake upgrade.
    USP Club Member #80
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Going to the 3.0L is one option. Picking up a B5S4 or B6S4 is another option.
    1.8T is 288mm, 3.0L is 312mm, and the B5S4 is 321mm B6S4 is like 345mm
    Better pads will also make for some much better pedal feel.
    Bilstein sports are suggested for lower springs. KONI sport are another very good option to consider.
    Dec 01 2007
    Quote Originally Posted by Mike@PureMS View Post
    Yeah but i heard the bilstien sports are great but a rough ride. And same for the KONI sport (yellows) are pretty rough. Only if the roads in the Noth East didn't SUCK! Thanks for the Info.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jul 19 2007
    San Diego, CA
    KONI's are noticeably more comfortable than the Bilsteins.
    If you're looking for comfort, definitely consider the KONI's.
