Results 1 to 11 of 11
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    Polishing out scratches in Ultrasport rims
    I have some swirlmarks and scratches in my rims that look like they are from the PO using too stiff of a scrub brush on them. I have some time off and was thinking about trying to get them out. Can you use polish and follow with wax like you would on your paint, or is there a better way?
    I didn't know if there was something different about the paint or clear because they are on the rims.
    I'd rather not get them refinished because the paint never seems to be as bright, or hold up as well as the factory.
    Current:
    '13 S6 Prestige [Oolong Grey Metallic, B&O, Innovation (HUD, Night, ACC, Active Lane/Side Assist., Top-view), Cold Weather, LEDs, 20"]
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Polishing out scratches in Ultrasport rims
    Eagle and Meguiar makes an aluminum wheel polish.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Feb 20 2008
    Naperville, IL
    Are these for painted rims, or just bare metal? Ultrasport rims are painted silver. Perhaps w/ a clearcoat, but not sure.
    Current:
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Did you already check the detailing forums?
    I think they are clearcoated.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    May 24 2007
    Southern California
    pretty crazy timing. this weekend i took off all four wheels and resprayed them, of course with detailed prep work before hand. but they turned out as good as new. the p.o. loved to park on curbs i guess.
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 20 2008
    Naperville, IL
    Hey man, those came out REALLY sharp! What paint/clear did you use? I found that in the past simply using Duplicolor Bright Silver worked well, but have yet to settle on a clear that doesn't yellow, and holds up well.
    I used Griot's clear in the past, and it sucked. Then went to something basic last time. Is a lacquer or acrylic the best to use?
    This was all on prior cars though. I feel like Audi RS4-style rims have more of a "shiny grey-ish silver" color from the factory, rather than the standard bright melallic silver, and have yet to find a paint that matches that.
    Current:
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    May 24 2007
    Southern California
    i used duplicolor T191 truck van and car paint. it is basically a perfect match.
    you can do one wheel and not tell the difference in shade.
    i didnt use a clear, cuz like you said, i didnt want the blotching effect.
    im thinkng about doing the two tone like the MTM wheel, but im not
    sure how to go about the seam that taping off the lip and side of the spokes makes.
    Kyle
    May 24 2007
    Southern California
    ANOTHER TIP
    For those of you who followed the A4mods curbed rim repair DIY.
    A much easier way to go about fixing the rash is, instead of using bondo
    to cover up all the blemishes, using a dremel with a sanding bit to sand
    away the rough curb rash works much easier. then use sand paper to get
    the smooth detail after the dremel. much faster and easier than bondo.
    Kyle
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    You will need to use bondo or something to fill the scratches if your curb marks are deep. If you want the wheels to match the color thay are new, use Wurth silver paint. It is a match for Brilliant Silver Metallic.
    You can get it here: http://www.autopia-carcare.com/wus-892181.html
    Feb 20 2008
    Naperville, IL
    any suggestions for the best clear to use? Lacquer? Acrylic? Others?
    Current:
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    May 24 2007
    Southern California
    Quote Originally Posted by akaEsCo01 View Post
    that paint probably works good. but just my experience, i taped off
    only a little bit of the lip the first time, sprayed it, took the tape off
    and there was no color difference between stock and t191.
    so both work fine i guess.
    Kyle
