Results 1 to 3 of 3
    Senior Member Three Rings jettman's Avatar
    Feb 27 2006
    punta cana, dominican republic
    constant coolant warning
    I keep getting the coolant light, and my car smells like coolant as soon as i get out of the car. i know these car can consume coolant but i refill it almost every 3 days. what d i need to look for?
    Kiss the rings bitch
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: constant coolant warning
    Do a visual on your rear coolant flange. It most likely is leaking because the o-ring seal broke.
    DIY with pictures to help you figure out what I'm talking about....
    http://audizine.com/forum/showthread.php?t=189137
    Also do a visual over all the coolant lines in the engine compartment to see if there are leaks anywhere else.
    -Doug
    Feb 27 2006
    thanks IL check when i get out of the office
