Results 1 to 2 of 2
    Mar 03 2004
    2014 Allroad, 98 A4 2.8, 00 S4, 03 3.0L A4
    Chelsea, MI
    2.8 30v Valve Cover & PVC
    Replacing the valve cover gaskets on my 1998 A4 2.8 30v. Doing this because I found oil in the spark plug wells.
    Got the valve covers off, not a fun job, but was able to do it.
    The valve cover vent (PVC?) was plugged! While moving the plastic vent line, I managed to break it in two places. Seems like the entire line is crispy.
    Question - I assume that I'm going to order a PVC hose. Is there anything else I need to get when doing this job?
    Thanks,
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    Re: 2.8 30v Valve Cover & PVC
    ya paint to paint the valve covers while they're off lol. the line you broke is the little one on the driver's side front right? you can just replace it with hose from like lowe's or something. i believe it's a 1/4 ID. check the big black hoses you took off the valve cover. they're probably plugged too so just take a screwdriver and careful clean it out as much as you can and put a little seafoam in there to dissolve it a bit. the job is much easier if you have small hands like me lol. good luck. if you haven't changed your ECT, it's pretty open right now so might as well do it
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
