Results 1 to 13 of 13
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Changing Radio Frequency with VAG
    Imported my car from Canada , and just got it today...
    anyways, the radio's frequency changes intervals by 2 MHz , and here in the UAE, I can't catch some of the local stations because of the jump..
    I have the symphony II radio, i know it can be done with a VAG cable, but does anyone know the codes and procedure?
    thanks!
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Changing Radio Frequency with VAG
    I found this, but its for the Nav plus..I need something like this but for Symphony II..some1 help me out!!!
    To turn off Navigation system acceptance screen:
    This modification also turns off the key in ignition chime. It can be performed on cars with the standard radio just for this reason. On those cars it will not change the radio settings or effect the AM portion of the radio like it does on the cars with the navigation radio.
    1) start VAG-COM
    2) click: “select control module” button
    3) in Direct Entry box type: 17
    4) click: RECODE 07
    5) In the Software Coding box should be a number (mine was 0007231). The second digit after the three 0s (2 in the above example) seems to be a region code.
    1 - Europe
    2 - USA
    3 - Canada
    4 - UK
    In other words by changing the coding from 0007231 to 0007131 you'd get rid of the acceptance screen! So enter the number you want and click: DO IT.
    6) click: close controller, go back
    7) click: go back
    One note: The Radio Issue:
    Europe uses different specs for their radio compared to North America.
    FM:
    FM frequencies in Europe are spaced .1Mhz apart, compared to .2Mhz in North America. This causes no problems in using a Nav Plus in North America, it just means you can tune into some frequencies (such as 92.2) which don't exist here. Since it can tune into all the North American FM frequencies that do exist, it works fine.
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Nobody? :(
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Have to bump this again, because I now registered the car over here in the UAE, and it is now my daily..so I need to get my radio working! someone!
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You should be able to recode it to where you live with Vag.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Quote Originally Posted by dirtybrd View Post
    Yes..but how?
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Have you tried contacting Ross-Tech?
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    I emailed them, dont know how long it will take to get a respone, but I'm hoping theres some VAG guru that lurks here
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    "According to the information I have found, the spacing is not adjustable in that model. A different radio would be used in areas where the frequency spacing is different. Regards,Andy"
    Im screwed :)
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Maybe you can install an aftermarket unit.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    If I remember correctly, Audi used different radios for Asia market, also made by Panasonic, I saw a picture of it once.
    May as well go for symphony II+.
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    2002 A4 3.0 Quattro Manual
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Tried...doesnt work..
    Cant recode past the digit "1" for the first value
