Results 1 to 8 of 8
    Jul 23 2008
    Perth
    Shaking prob HELP
    hey, okay i have had this problem for about 1year what seems to happen is that in 1st 2nd(especially) and 3rd gear id get like a jutter/shake just before it shifts! If i drive the car hard it doesnt do it only wen i cruise it! I have no idea what it could be? Any ideas plzzz?
    Also what i am cruising on the freeway doing about 100km/hr and if i totaly release my foot of the accelerator the revs would drop then go up then drop n go up untill i put my foot back on the accelerator wired HUH? any thoughts would be greatly appreciated cheers
    1998 2.8L tiptronic B5 (A4)
    Jul 23 2008
    Perth
    Re: Shaking prob HELP
    no1 has any idea?
    Aug 09 2008
    South Africa
    I have the same problem. Car has only done 8000km's and it shakes in 4th and sometimes 3rd under similar conditions. When I reduse speed it shaked and when I accelerate its fine.
    Jul 23 2008
    Perth
    hrm ye prity much its wired mite be injectors cos i noticed wen i use 98 octane its not as bad? do u rekon using 91octane could of caused this? What fuel do you use?
    Aug 07 2008
    ID
    how about fluid transmission? make sure it is on up-level.
    Active Member One Ring iwt5007's Avatar
    Aug 08 2008
    b5 A4 99.5
    Phoenixville
    check your coilpacks (ignition coils) and/or spark plugs thats what mine was doing for awhile until i replaced the spark plugs.....after that in about 15,000 more miles it happened again...when i found out my coilpacks were spent
    Jul 23 2008
    Perth
    hey thanks for the replies i got my tranny fluid changed about 4months ago and i have done ignition lead change also about 4months ago so i will try the spark plugs!
    I was thinking could it been cause i was using 91octane fuel instead of the recommended 95octane! What i noticed is when i used 98octane it runs much better the shakes and jutters arnt as noticable?Ingector cleaner?
    Aug 09 2008
    South Africa
    Hi, We us 95 octane here in S.A. Oh and its a manual tansmission. I've booked it in, so the dealer can have a look at it, hopefully they will get to the bottom of it.
