Results 1 to 10 of 10
Thread: Just got a CEL
    Registered Member Two Rings 3l r3Gi0's Avatar
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Just got a CEL
    Just yesturday i did an oil change on my car and today as i was driving from walmart lol my CEL came up. Does it have anything to do with me changing the oil.
    Can one of those autozone lil scaners can tell what the hell happen. or i need a special scanner for the audis.
    Thanks
    Dec 05 2007
    Re: Just got a CEL
    Nope. The Autozone can get you the code. Then you would need to look it up from here. If you can not find it on there, you should post a new thread inquiring of what that code relates to. People on this forum should be able to help you from there. Peace!
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Re: Just got a CEL
    bump
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Just got a CEL
    Did you reconnect the coolant reservoir sensor? (if you took it off)
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 05 2007
    Re: Just got a CEL
    I don't know about oil changes in a 2.8, if that is what you have. But did you go check to see what codes they were?
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Re: Just got a CEL
    naw man i got a 1.8T and na i havent checked the kodes hopefully this thursday
    Dec 05 2007
    Re: Just got a CEL
    Get your codes checked. No one can help you if they don't know what the CEL is for. Why not do it now. It takes maybe 2 min. You scan the car and write down the codes. Then you clear the codes from the ECU (there will be option on the scanner to clear codes). Your CEL will go away. And if problem is still there, it will pop back on. Then go to the link I provided and see what it means.
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Re: Just got a CEL
    aight man thanks, ima see if i can get the codes u said i could get them from autozone right?
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Re: Just got a CEL
    Quote Originally Posted by 3l r3Gi0 View Post
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Re: Just got a CEL
    Quote Originally Posted by matt719 View Post
    kool ima do that first thing tomorrow again thanks for ur help
