Results 1 to 12 of 12
    Senior Member Three Rings tommy782's Avatar
    Aug 01 2008
    canada
    sensor coolant code
    my fans on my a4 1.8t 2003 doesn't work (2) and I have a coolant sensor code (G83) and I just want to know if this is the upper or the lower sensor.
    thx
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: sensor coolant code
    what is the five digit fault code? G83 doesn't help me.
    For example: "16496/P0112 - Intake Air Temperature (IAT) Sensor 1 Circuit (G42): Low Input"
    -Doug
    Aug 01 2008
    canada
    the code is
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 002 - Lower Limit Exceeded
    thx!
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Funny ive been getting the same code and i swapped out the sensor on the lower radiator hose(grey 2-pin) only today. Im assuming thats the outlet. The green 4pin i swapped out when I first got the car so i cant imagine thats the cluprit. Ill have to scan the car again and see if the code comes back.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Aug 01 2008
    canada
    ok give me somes news because I don't like this when I see the temp gage at 130!!!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by tommy782 View Post
    the code is
    thx!
    Have you checked the sensor at the lower radiator hose? I believe that is where this signal is coming from. If you are going to replace it also pick up a new sensor for the rear coolant flange in the back of that head. That one typically takes a shit. When it does, the car runs super rich. Both replacements should be green in color.
    proper sensor: http://www.purems.com/products/product.php/II=1472
    sensor clip (in case it breaks on you): http://www.purems.com/products/product.php/II=1491
    o-ring seal: http://www.purems.com/products/product.php/II=2192
    (You don't need the clip and seal if your original stuff is okay)
    -Doug
    Jun 24 2008
    E46 M3
    Woodinville WA
    The radialtor fan switch should be a two pin grey sensor. Have never had to replace one yet. Replaced countless green sensors though. Them sensors are a dealer only type of part to avoid problems later.
    Though, based on what you're saying and my experience with AMB 1.8T's, I would suspect the Thermostat to be faulty. Very commonly see those T-stats causing the coolant to circulate mainly through the heater core and hardly any through the radiator. Unfortunately, the t-stats in AMB 1.8T's are the biggest joke ever.
    C
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Affinitive View Post
    C
    Have you had any luck with retrofitting an older (2001-ish) style thermostat onto an AMB? My only concern is the ECU freaking out when it doesn't have a signal from that heating element on the AMB thermostat. I've been thinking of installing the older style system on my engine.
    -Doug
    Jun 24 2008
    E46 M3
    Woodinville WA
    Never tried or thought of trying. The little heater element in the stat can be unplugged and not set faults. Like BMW, the idea is that the ecm can force the stat all the way open when extra cooling is required by applying current to stat. As for converting.......I would think it to be quite a project as it would require new lower rad hose for the regular stat housing, different coolant pipe on top of intake and coolant flange and different heater core plumbing. I think the best bet would be to convert all the cooling system stuff to that of an AWM engine. I'm sure it could be done as long as the stat housing fits. The concern with the stat housing being that the AMB has a totally different alternator and bracket mounting to the engine than all the other 1.8's. So I'm not sure if a regular housing would clear the Alternator/bracket assembly. HHHMMM, now I'm curious.
    The AMB is great and all but it kinda sucks in the fact that it's the most unique 1.8 out of all of them.
    C
    Aug 01 2008
    canada
    I finally found my problem. first I change my coolant sensor on the radiator hose. the code doesn't appear on my computer but the fans don't start!!!.I search and I found a wire on the module. the wire was cut and the contact doesn't pass. I weld this wire and the fans work great!!!. I save 250$$!
    ThX AuDiZiNe!!
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I would check with your dealer about the rear sensor if it is bad. Audi covered mine under an extended warranty program due to problems with the original sensors that were installed at the time of manufacture. It's worth looking into.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Dec 03 2005
    2 pedals 1FG
    connecticut
    C
    What I highlighted in bold is exactly what I've been trying to figure out. Then again, I guess I could have unplugged mine and checked with VAG-Com.
    I'll have to look over my friend's AWM engine a bit more closely. I didn't realize the upper hard line was different. I knew I'd need a new lower radiator hose and have to get that hard line that comes out the back of the water pump region on the block... And retrofit the heater core lines. etc.
    Before doing all of this I am going to see if we can tweak the map within the ECU... All in an attempt to get the engine to run a bit cooler, to make more power safely. It'll come down to whether or not my tuner wants to do this. Its all theories in my head right now.
    -Doug
