Results 1 to 18 of 18
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    help - strange suspension clunk
    Ok, so after changing my rack and pinion my car is still making a strange clunk noise from the drivers side front suspension. The thing is that it only makes it when driving slow over road imperfections. A technician had the car for a week and check "everything" and said that after tightening everything up it was fixed; but it is still making the noise. He also said that the upper strut mount bushing was perfect. Could it be that the shock is damaged? The car feels perfect when driving around, its only when driving like below 15mph...
    I also changed all my control arms last year, and they still look perfect and have no play when I try to move them...
    Thanks guys!
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Jan 18 2005
    Puerto Rico
    Re: help - strange suspension clunk
    anyone??
    this has me very disappointed with my car, and if the car keeps making strange things im gonna sell it and go to the dark side.. haha
    FlexTuning
    Senior Member Two Rings BIG EYE's Avatar
    Sep 22 2005
    A4 USP 3.0Q/A3 SLine
    San Diego
    what suspension are you running?
    My car is doing the exact same thing w/ Vogtland coilovers.......
    Sep 22 2005
    San Diego
    you ever figure out what is causing this. I just spent an hour under my car searching for the culprit, with no luck
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    they top strut nut is not tight all the way... i would check that ASAP.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2006 VW Touareg (on blocks in my driveway). 2007 a4 2.0. 2003 a4 1.8tqm sport (sold)
    Ummm the Jersey Shore
    I had a shim missing from my brakes when I testdrove my car at the dealer. I told them get rid of that clunk and i'll buy the car. haven't heard it since. Check your brakes.
    Miss my B6
    Sep 22 2005
    San Diego
    Quote Originally Posted by Audi Skate Snow View Post
    You mean the 3 bolts under the hood? Those are tight....
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    This is true. Not the 3 bolts, but the top center one, that holds the spring onto the strut. It must be installed with an impact wrench. HTH
    USP CLUB MEMBER #686
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    I have the same noise but from the rear, probably the diff. But im tired of guessing so i'm going to a parking lot, turn my wheel all the way in one direction and floor the gas with esp off. I'm sure something will break and that will take all the guess work out of it.....thats how annoyed I am!
    Sep 22 2005
    San Diego
    Quote Originally Posted by Grenade View Post
    I'll have to pull it out and check that. It was installed with an impact though......
    Mar 31 2004
    CA
    Quote Originally Posted by BIG EYE View Post
    yes, from my previous post I was refering to the actualy top strut nut.
    if it is not tight all the way... like even barley loose... then everytime you hit a bump you will here it bottom out and it will clunk everytime.
    im willing to bet that is the problem.
    Even wtih an impact gun you have to sit there for a second until it stops turning..
    Mar 31 2004
    CA
    shit if you want to drive to me (ontario) ill go ahead and look at it for you and fix it for ya.
    Senior Member Two Rings giacb6usp's Avatar
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    ITS FROM YOUR BRAKE... THE SOUNDS COMING FROM THE BRAKE PAD HITTING THE CALIPER HOUSING. Jack up one side hit the tire at 12 oclock then hit it again while pressing down the brake pad. I'm pretty sure its brake pad...
    USP CLUB MEMBER #4
    K04 - Miltek Exhaust - PSI TP - Racetec FMIC - TT 225 - SB OFE SS - AWE Boost Gauge - AWE Tuning Pedals - Forge 007P- RNS E - Oettinger - Apexi TT - Fujita Filter - S4 F.Grille - ECS D.Mirror - Hawk HPS F/R - Hardwired V1 - Hitachi E CP - Bosch FR5DTC - H11 Höen Xenonmatch - APR Snub - VAG-COM License with HEX-USB+CAN Interface -
    Sep 22 2005
    San Diego
    Thanks for the offer! I'll be able to handle it though
    Sep 22 2005
    San Diego
    Quote Originally Posted by giacb6usp View Post
    Are you saying to have some press the brake peddle or to hold the pad with my hand while hitting the tire?
    Also, what should i be looking for while hitting the tire?
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    I mean pressing the actual brake pads with your hands so that it doesn't vibrate or hit anything while your hitting the tire with your hands.
    USP CLUB MEMBER #4
    Sep 22 2005
    San Diego
    I will give this a try.....
    Jun 17 2007
    Yeah, the shim was missing between my caliper and pad and it was causing the caliper or pad to make a clunking sound over bumps and on turns. They replaced the shim/spacer and the clunking went away. Quite possibly the culprit.
    Miss my B6
