    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    I lost my boost gauge reading
    I uninstalled my cold air intake to clean the filter and re-oil today. Now my boost gauge doesnt work, car still feels like it is boosting though. There is no vacuum or boost reading.
    I'm very new to the S4, so can anyone help me out? Something I forgot?
    And, the only other thing I did was open up my ecu box to check the number and screw back on...looks like the boost gauge wire runs through there too.
    Thanks in advance
    /edit: Found the problem. The ECU box was screwed down too tight ontop of the boost line, fixed the crimp. /thread
    Apr 13 2008
    Tennessee
    Re: I lost my boost gauge reading
    maybe you accidentally unplugged one of the wires
    Jul 13 2008
    yeah, checked that...is the boost gauge wired to the intake and maf at at?
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    Yeah I would assume you it will be the hose from the boost gauge. It runs out from the ecu box nad maybe you yanked it a little and it could've gotten disconnected from the unit. Otherwise the wires don't really run to the ecu box (installed my boost gauge two nights ago).
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    my boost gauge (APR) has the line running from out of the FPR thru the firewall to the gauge. It should not be plugged into your MAF, since you're not running boost at that point
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
