    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Need help with removal of fan pulley!!!
    I am doing the timing belt on a friends S4 and dont know how to get the fan pulley off to get to the one behind it. i searched but all i found was the DIY timing belt but it doesnt show how to take it off. thanks in advance.
    Felipe
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: Need help with removal of fan pulley!!!
    Quote Originally Posted by pipe7284 View Post
    Felipe
    there is actually a special tool that keeps the pulley still while you turn the nut. the DIY mentions it as the "chopsticks tool" and says he made due without it but didn't say how. What I did was, on the bottom side behind the black pulley there is a hole about an inch deep. You stick the short side of a 6 or 7mm allen in there through one of the long slots in the black pulley and turn the pulley so the allen stops the black pulley from moving. then take a cresent wrench and put it on the nut that connects the 2, and turn it to the RIGHT. its a reverse thread.
    putting it back on is the reverse obviously, but make sure you have a slot with the allen snug, or else you may bend the clutch fan blades or the pulley. Turn it to the left when tightening.
    Established Member Two Rings Krzano's Avatar
    May 04 2008
    B5 S4 stage II
    Chicago, IL
    The threads on the nut that holds the fan on is left hand thread. I used a adjustable wrench and tapped it with a hammer usually loosens the nut right up. I can't remember what I did to hold the fan from moving. Mine came off fairly easily, good luck with yours. Hope this helped.
    Sep 14 2006
    Lansing, MI
    thanx guys, i`ll try it out and if i dont come back to this thread means it worked!!!!!
    SOLD
    Feb 17 2008
    Ottawa Ont.
    if you are doing all that, i highly recommend the VAST EFK kit. That fan clutch thing is horrible.
