Results 1 to 22 of 22
    Established Member Two Rings midnyite's Avatar
    Jun 28 2007
    Help with misfiring on certian cylinders
    What does it mean when only certain cylinders misfire. And it seems it only happens when i am in boost. Dont remember the exact cylinders but something like 1 , 3, 6.
    Also i am tryin got find a boost leak or problem somewhere with my turbos whining like shit. Sometimes i cant hold boost, sometimes i can. There are times when it overboosts to 25PSi and then it goes back to normal where it boosts 21-22. Then it wont go past 17-18 sometimes. This shit is wierd cant figure it out. Had the shop smoke test it and they say there are no leaks. Does this sound like N75 failure or DV? DV were brand new from about 8 months ago.
    Thanks
    Jun 28 2007
    Re: Help with misfiring on certian cylinders
    Also what is the vacuam supposed to be at when sittiing still?
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    If the misfires keep coming back to the same bank of cylinders, it's likely that the ICM is bad for that side. If you have the time/patience, you can swap the coil packs just to be sure. That might be related to your boost issues, but you might just wanna log blocks 115 just to see what's going on.
    edit: vacuum should sit around ~20inHG, or ~17inHG with the a/c on.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    what do you mean by whining? Like dentist drill? Cuz the turbos themselves could be bad. Also, have you checked spark plugs for misfiring?
    Sep 16 2005
    Asheville, NC
    Your valve cover gaskets could also be leaking and causing certain cylinders to misfire. I have that problem right now but haven't had time to fix it. Actually mine is very similar to what your are describing except that I never actually overboost. Maybe check that as a last resort?
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Established Member Two Rings cmagalis's Avatar
    Aug 01 2008
    2000 B5 S4 & 1997 B5 2.8Q A4
    Lakeville Mn
    Well it could be one, or many problems. For the miss fire it could be a bad coil pack. As for the boost problem, the turbos should be fine. If there isn't blue smoke pouring out the back your ok. When you run 20+ psi of boost your looking at a ton of new issues anyway. The turbos will make some noise because they are compressing air and have an inlet. To me it sounds like theres a bad sensor or valve somewhere in the car. My recommendation for you is to find someone with a VAG scan tool and have them do an engine log.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    how many misfires/ cylinders, which cylinders and does it throw a code or CEL?
    B5 S4 AWE Stage 3 - sold
    Aug 01 2008
    Lakeville Mn
    Also a very good thing to check too
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    The boost issues sound like a bad N75, but with the misfirings, your problems could be deeper. Have you installed new plugs recently? Have you scanned the car?
    --Adam
    Have questions? E-mail me.
    Jun 28 2007
    Only misfires when i am in boost, IIRC it is 1 , 3 ,6
    Quote Originally Posted by Rajan147 View Post
    Jun 28 2007
    What is a ICM?
    Quote Originally Posted by BITRBO View Post
    Jun 28 2007
    So this is what i have gotten so far.
    Boost leak can be a N75 or DV, or maybe even a leak from the inte3rcooler or hose?
    Turbos did not whine before the installation of the intercoolers. This is like major whining at boost, not your regular startup. Also is coming only fromt he right side.
    ALso the DV's are only 8 months old, hyper boost DV's do they actually go bad?
    As for the misfiring, Coilpack? Plugs? just had them installed about 1500 miles ago. Bosch Platim plugs.
    Vaged the car last night and only got the misfire and something with my o2 sensor. But i have been having tha for a long time since i am running test pipes.
    Will get some logs tonight. First what blocks to log and second can someone help me graph the data?
    Thanks
    Sep 14 2006
    14 GLI
    ICM = Ignition Control Module
    Jun 28 2007
    Jun 28 2007
    Just checked the misfires and they are cylinders 1,2,3
    Also did some logs, anyone here can help me put that in graphing and tell me whta swrong with the car?
    Thanks
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    Quote Originally Posted by midnyite View Post
    Thanks
    swap the ICM's (top of the airbox) then vag the car again. if it jumps to the other side, well then thats it
    Jun 28 2007
    Dam, thats a good idea. Thanks!! Will definetly try that.
    anyone else can help with my logs?
    Aug 01 2008
    Lakeville Mn
    Honestly it may be worth taking the car in so you don't end up spending money on un-necessary parts. It's a lot easier for a trained pro to give you the right info. Then fix what he tells you! It's not a bad thing!
    Aug 01 2008
    Lakeville Mn
    As for the o2 sensor bugging out its probably one of the probes in down pipes. There are few aftermarket down pipes that dont throw faults for cat efficiency. Most of the aftermarket dps' run fewer cell count units than the factory Leistritz cats to give less restriction.
    Jun 14 2007
    2000 S4
    Connecticut
    when you misfire in boost, thats usually a GAPPING issue on the plug. what plugs did you install?? try re gapping the plugs OR try the Bosch F5DPOR Plugs everyone talks about. I have them in my car and runs great. they come pregapped you dont touch em!
    Jun 28 2007
    Thats what i am using now. the plugs are only about 1500 miles old. So it should nto be the plugs.
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    It could be a tonof things!!! having bad o2 sensors will make ur car misfire bad too!!!!
