Results 1 to 3 of 3
Thread: lock problem
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    lock problem
    so my friend just got a 98 2.8 and it's in great shape. he got an extra remote and key cut for his car so we decided to program it. so we put the one that was already programmed into the ignition, and we put the one that was not programmed into the door. then we started to press buttons and turn keys to try and program it but it didn't work. can doing it wrong actually erase the coding from the key that was working? i've never heard of that happening. i also used vag com to do the remote windows, one touch unlock and the autolock at 15+mph. the original coding was 16140 and after the math i ended up with 16232 which i believe is right unless i'm going dumb. also, his button on the driver's door won't unlock the doors afterwards either. the button locks but won't unlock. the locks work fine using the key in the door method though. i'm totally stumped about this. i have the DIY from audiworld but the fact that not even the button on the door works really throws me off. hopefully somebody can help TIA
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Re: lock problem
    Trying to code another remote will erase the old remote(s)... when you get the coding to work, ALL remotes have to be learned by the system.
    Its possible the button on the door is bad... or the system just hasnt started accepting a signal from it. When you try to learn remotes or recode the module, certain parts dont always work right away. Like if you disconnect a window motor, the auto up and down do not work right away.
    Sep 13 2007
    PA
    Re: lock problem
    upstate ny FTW!!!! thanks jared. what about the switch on the door not unlocking the doors problem? it locks but doesn't unlock
