The brake piston may need to be pushed back. For rear brakes, you have to get a C clamp and push the piston back in. Biggest thing to remember is you need to turn the piston as you push it back in.
That may sound confusing but really its not. take a screw driver and jab it in one of the grooves on the end of the brake piston and take a hammer and tap on the end of the screw driver to turn the piston clockwise then put a C clamp on it and push it in. This way it allows the caliper to open up and fit over the pads and rotor.
Here's a pic I found on internet: (note: this picture is of a front caliper, for our rear calipers you will need to take the brake pad out of caliper, and clamp right onto the piston and the other end of the caliper. (turning it while you push piston in)
[IMG]
[/IMG]
The biggest thing to remember is turn and push, turn and push
I only say this because one time i went to replace the rear brake pads and got the caliper off in 5 minutes, went to put the new ones on and thought I'd have both brakes done in less then half an hour. Then two hours later still on the same caliper I was so frustrated because I couldnt get the caliper over the new brake pads.
I then talked to someone I knew who was a mechanic and he told me you had to turn the piston as you pushed it back in. Once I did this it was a piece of cake
