Results 1 to 11 of 11
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    Omg Another Problem....
    after finding out i need a new abs module.... i was driving up a hill and it seemed like my car wasn't going to make it because it was losing power. i start to smell like rotten egg smell and my car was shaking pretty hard. boost seemed normal.... my engine coolant seems to be going down pretty fast... i have no idea wtf it is. anyone have any ideas???
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Omg Another Problem....
    Rotten egg? Was your AC on? What gear were you in? VAG that sob.
    Aug 01 2007
    2000 S4
    Daly City
    AC wasn't on... was in 2nd gear.... im being told its my downpipes... can anyone 2nd that?? and if so.... are there any aftermarket downpipes that will pass smog???
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Sulfur smells like rotten eggs. Sulfur is what it is in your cats., you hacve bad cats. Vag your car and see what codes come up, and also if your losing coolant and your not seeing it on the ground and your not seeing it come out of your tail pipes then its going into the crankcase. Do an oil change and send a sample to blackstone. Goodluck bud
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    how did i know this was going to be a post in the b5 s4 forum before i clicked the title link?
    good luck with the fix.
    Aug 01 2007
    2000 S4
    Daly City
    i brought it to the shop and they told me the problem was my 2nd cylinder is misfiring... but he said that it might actually be the whole engine thats jacked up... what are the chances that its my whole engine??
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    someone in SF should be able to help you vag-com it.
    if you are misfiring it could be for a number of different reasons probably not related to the cat issue.
    go to autozone and get a compression tester if you think theres a problem with your motor. "it might be the whole engine..." dont listen to that nonsense. get answers for yourself!
    Apr 05 2007
    Quote Originally Posted by LIFES4 View Post
    engine coolant going down fast + cylinder/engine issue could very well be a blown head gasket. which, depending on circumstances could mean significant engine damage.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by exorcet View Post
    i was thinking blown HG too but i didnt say it because its all speculation without doing the proper tests.
    Aug 01 2007
    2000 S4
    Daly City
    UPDATED.... he told me it was the ignition module that is causing the misfire in cylinder 2... shouldnt it be causing the other 2 to misfire too?
    Jun 14 2007
    2000 S4
    Connecticut
    if you want to check that out to see if its correct, switch the wires around on the ICMs on top of the airbox. take the big one from one and clip into other take small from one swap to other etc.... dont have to literally MOVE them, just the wires... if the misfire follows to the other bank then that's your problem
