Onemoremile, did you have smoke coming out of your exhaust or the engine when you before you found the tear? Cause my car seems to do it only after I drive it for a while and then I idle it. Once I start moving, no smoke.
Andyrew, I will check for leaks on my connections, but as far as I know, there are none. I looked around the connections and didn't find any dry coolant or oil.
AudiRacer, I would suspect the turbo as well, but the turbo is 2 weeks old.
Yaktizzle, maybe it's because my turbo and yours are hybrids. Mine is a ko4 with a 1mm larger compressor wheel than the ko4, but the stock turbine wheel from the ko3. Maybe that's what's causing our problem.
I also suspected the head gasket, but wouldn't my compression be messed up? When I checked my compression, it was all in the 180s. With my ko4 before it blew, there was no smoke at all. I would think that 2 weeks is plenty of time to have all of the oil that got into the engine from the turbo blowing to burn out.
Any other opinions? I was even thinking of trying to track down a ko4 to swap in just to see if the smoke would go away. If it does, then it's obviously the turbo. That would tell me that hybrids obviously don't work too well.
When I changed my spark plugs a week ago, I did see oil in the cylinders, but that's from when my turbo blew and oil got everywhere. I had about a quart in my intercooler alone and some in the intake mani. I'll check again to make sure there isn't any left there. If it was the oil that was burning from the engine, wouldn't the car smoke all of the time?
