Results 1 to 11 of 11
Thread: What is this?
    Veteran Member Four Rings HP18's Avatar
    Jul 18 2004
    Orange County - CA
    What is this?
    Well I had my car up on a lift today and noticed a bolt missing here. What is it supposed to be holding together?? It's missing on both sides. The driver side is snapped off.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: What is this?
    bump for curiosity
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 30 2007
    A4, S4
    Orange County, CA
    Re: What is this?
    bump cuz i like this car
    Veteran Member Four Rings TDI's Avatar
    Nov 13 2006
    a4 avant B7
    Belgium
    Re: What is this?
    looks like the swar bar stuf hitted the carrier of the subframe
    look's not good dude!
    -God show me the way..because the devil try's to break me down-
    Kanye West
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: What is this?
    that looks like the spot the factory uses to align the subframe and when doing alignments techs use it to help adjust the subframe
    dont worry about it
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Jul 18 2004
    Orange County - CA
    Re: What is this?
    hmm..more inputs people
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: What is this?
    I agree with the alignment point.. there was a thread about it few weeks ago
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    Re: What is this?
    Same on my car, don't worry about it!
    Wow, I can't believe I just helped with your car haha
    Amazing ride BTW...
    Jul 18 2004
    Orange County - CA
    Re: What is this?
    alright thanks, just wanted to make sure!
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Re: What is this?
    yes, that is the place you stick a dowel thru when re installing the front subframe. you insert the dowel rod on both sides then tighten down the sub frame bolts... nothing is wrong with your car
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Re: What is this?
    ^ +1 dude.. Your good!
