Results 1 to 18 of 18
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    Help! somethings leaking!
    I just did the K04's 3 weeks ago and have put about 800 miles on it and yesterday something started to leak boost and it was the turbo(s) sounded ten times louder. we pressure tested it and found a broken DV so I threw some bosch ones on that are fine no leak.
    then i was test driving it 1st gear fine thru 6000 rpm 2 fine untill about 4200 rpm right after full boost hits it looses all power and bogs down. then my friend driving behind me said i was super rich and after it popped he said there was a gasy cloud or something.
    is it something to do with spark plugs being to hot and needing cooler ones or a hole/slit in a hose somewhere? possibly something to do with the turbo itself or what??!?!?
    '00 Nogaro Blue S4
    Feb 17 2008
    Ottawa Ont.
    Re: Help! somethings leaking!
    boost leak.
    dont overthink it.
    Feb 17 2004
    Sterling, VA
    So after the DV replacement, you did another leak test and found no leaks?
    When you did the K04s, was the rest of the Stage 3 hardware and the intercoolers installed at the same time?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jun 13 2008
    Rocky Mountains
    Thats what i was thinking too.
    Everything was done at the same time. and it ran perfect for about two weeks. this past week its been super super hot so i havent really been getting on it at all and it was cooler the other night when i romped on it and felt the massive power loss.
    We put a cap with a air compressor adapter on it where the MAF goes and plugged all the other holes and with the bad DV off of it and the ends of the rubber hose clamped off didnt seam to leak. I will be able to pressure test it again on monday.
    that leak is probably coming from turbo to intercooler or intercooler to engine? or where would i have the best luck of finding this leak?
    '00 Nogaro Blue S4
    Dec 06 2007
    Calgary, AB, Canada
    Could be a lower IC hose that popped off.
    Jun 13 2008
    Rocky Mountains
    im going to be able to throw it on a lift tomorrow. a big deal to drive around with it as is if i stay out of it?
    '00 Nogaro Blue S4
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    if you lost a hose somewhere, do not drive it. you are pulling UNFILTERED air into your intake. If you get something nasty in there it sould cause problems. If you did not lose a hose and have a small leak, it will be ok to drive it and stay out of boost. does it make any boost at all? any CEL's when you lose power? can you VAG the car? boost leak test first!!
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Jun 13 2008
    Rocky Mountains
    Quote Originally Posted by obijohn22 View Post
    first gear pulls all the way thru 6k rpm no leak second gear all is fine untill 4300rpm then no more power its like nothing is there. the turbo(s) sound loud as hell. im sorry i dont know what VAG or CEL is.
    '00 Nogaro Blue S4
    Oct 31 2005
    Ashburn
    VAG= scan tool for CEL and other problems.
    click http://www.awe-tuning.com/pages/shar...ps&IL=RossTech
    CEL= Check Engine Light
    - Instagram: @Sinister_rs5-
    Jun 13 2008
    Rocky Mountains
    yeah thats the thing no check engine light, and i know that it would light up like an xmas tree cause when we first fired it up there was like 10. but no as of right now with a massive boost leak there are no check engine lights on. i took the bottom ic hoses off and checked em out did not seam to be leaking. what else could it possibly be?
    '00 Nogaro Blue S4
    Oct 31 2005
    Ashburn
    Do you have all other upgraded hoses, f-hose, Throttle body boot, etc..?
    is t just under boost? what is your vaccum like at idle?
    Jun 13 2008
    Rocky Mountains
    it actually wasnt leaking i guess they are broken in or something lol. the check engine light finally came on it turned out that every cylinder but 1 and 6 was miss-firing so we think the plugs have been getting too hot and they are the ones that came with the awe kit, the gap was at .08 and it should have been .06. so i ordered rs6 plugs from the audi dealership and if its not that then my guess would be bad coils
    '00 Nogaro Blue S4
    Jun 13 2008
    Rocky Mountains
    no i dont have any of that, we pressure tested it all the way to 90 psi no hissing or anything.
    i assume the vac is fine since it was missing
    '00 Nogaro Blue S4
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    yea check your tbb could be busted, and what kind of dv's did you replace them with? stock s4 ones?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Oct 31 2005
    Ashburn
    Quote Originally Posted by AMC83189 View Post
    Exactly^^. you should def. check out f-hose and TBB.
    I blew both those hoses just being stage 2+ running 17-18psi
    You being stage 3 with more boost, i just don't see those hoses holding up to that kinda boost. I would change them out if there stock, You can go with some cheap but decent $100.00 ASI kit off ebay of just order SAMCO hoses.
    Jun 15 2007
    and is it just me but the gap on your plugs are just wayyy to low, arent they supposed to be .24 on stage 3 or around there?
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jun 13 2008
    Rocky Mountains
    on the computer it said .06 i thought. I have bosch DV's that avalon motorsports had the tech said that hes put those on a hand full on stage 3's and they have been working fine. he also said that if i were to put tbolt clamps (which i did) that the stock hoses would be fine. we pressure tested it to 90 psi and nothing was leaking
    '00 Nogaro Blue S4
    Jun 15 2007
    Quote Originally Posted by NogaroWonda00 View Post
    90psi and u didnt blow anything by running that much air thru? you pressure tester normally pops off at around 35-40psi
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
