Results 1 to 12 of 12
    Aug 24 2005
    1999.5 AUDI A4/T/Q/M
    Chicago, IL
    Anyone got info on Fidanza
    Well here's the story, my car has 136,000 Miles I bought it May 19th 2006 with 123,000K so I really Have only driven like 10,000K miles in 2 years. I already got my Tbelt kit I am now looking at Clutches and flywheels.
    I ran across one called "Fidanza Aluminum Flywheel" Does anyone know if they are a reputable company?
    http://www.fidanza.com/
    **INFO**
    Fidanza Aluminum Flywheel Audi A4 97-99
    Fidanza aluminum flywheels are made from the highest quality 6061 T6 aluminum.The material is fantastic for strength, heat dissipation and of course reduction in weight.The friction surface used is an incredibly strong 1050 steel.The plates are milled to meet Fidanza's high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners.The ring gears used are also made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws. Fidanza was the first to utilize a stepped dowel system in most of their flywheel applications.This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. No chromemoly can compete with the awesome serviceability, strength and superior design of Fidanza's aluminum flywheels.
    Flywheel weight: 10lbs
    Engine: 1.8L
    -Spiel
    Apr 22 2007
    Riverbank, Ca
    Re: Anyone got info on Fidanza
    Thats a really light FW.. your going to get a ton of chatter on that.....
    I have a SPEC flywheel, 16lbs, and I still get some chatter, but its livable.. Its way lighter than stock, and I wouldnt go any lighter on a daily driver personally..
    give Mike-2ptzero a pm.. he's got a good deal on a clutch/fw kit
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    My 16lb chatters too, wasnt there a cheap 9lb floating around somewhere? i wonder what thats like?
    As a brand i believe Fidanza to be a good one, but i am sure i read somewhere about the alloy flywheels bursting maybe?
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Aug 24 2005
    Chicago, IL
    I want room for next year...I was trying to sell my car but with the economy and recession I am going to keep it for most likely next 5 years.
    Stuff I have not yet installed
    -Control Arms (full kit)
    -Tbelt (Full kit)
    -Snub Mount
    Needed
    -Shocks
    -Springs
    -New Tires (with rims) still have stock rims and tires that came with the car.
    -Clutch/Flywheel
    Wanted
    Sparco Seats
    Short Shifter
    New carbon fiber hood (Old one is a piece of crap)
    Carbon fiber trunk
    Installed **MODS**
    Carbon Fiber VIS Invader Hood (Silver Painted) /Sparco Hood Pins
    S4 Chrome Mirrors
    15% Tints 360 Degrees
    NeuSpeed Rear SwayBar
    710N Diverter Valve
    Borla Exhaust V1
    Ecode Test Pipe
    CHIPPED GIAC
    AutoMeter Pillar
    VDO Oil Pressure Gauge
    Cyberdyne Digital Air to Fuel Ratio
    VDO Boost Gauge/IN vent with custom PLexxy Glass
    Zimmerman Rear Drilled Rotors/Mintex Brake Pads
    Front Drilled/Slotted ECS Tuning Rotors/Hawk Street Performance Brake Pads
    DeBadged
    OEM S4 Xenon HEADLIGHTS "Clear Corner Mod" 6000K
    Hella Micro Fogs
    Alpine 9847 Headunit
    (1) Kenwood AMP
    Greddy Turbo Timer
    Rs4 Grille
    Feb 27 2005
    North Wales, PA
    The fidanza is closer to 9 lbs. Not too much chatter on my friends car. Only with the ac on can you hear it past the exhaust. Whats the big deal with chatter anyways?
    Jan 20 2005
    99 AJL TQS
    UK
    No big deal, its just a worrying sound when you first hear it. I thought my gearbox was shot,lol Also it gets more pronounched the lighter you go doesnt it?
    -Mark -
    Aug 24 2005
    Chicago, IL
    It would be ok matched with a Stage 1 clutch right?
    Feb 27 2005
    North Wales, PA
    you can match it to whatever clutch you want. Just be sure to get the unsprung hub.
    Jan 20 2005
    99 AJL TQS
    UK
    Quote Originally Posted by Poopie View Post
    Un sprung? Surely its unsprung for DMFW and sprung for single mass?????
    -Mark -
    Feb 27 2005
    North Wales, PA
    the fidanza does not have a recess for the flywheel bolts so the sprung hub will not fit. The solid hub is dome shaped to accomodate this. If you want a LWFW and a sprung disk then get the AWE one. Its pricey, but you got to pay to play.
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    I just installed one with South Bend stage 4, i will post some pics later~
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    I have a 9lber fidanza on my car. I dont hear any chattre right now, but then again i have only a downpipe right now...
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
