Results 1 to 24 of 24
    Jul 27 2008
    long island
    S-line springs ?
    Is there a difference in ride height from a s line and an non line. I am looking to maybe lower my car, but I live in NYC where the roads are bad and i travel up state where it snow alot. so i dont think i want to lower it as much as an after market springs
    Registered Member Two Rings Ivory 305's Avatar
    Sep 10 2007
    08' Ibis A4 S-Line/Titanium
    Miami, Florida
    Re: S-line springs ?
    yes there is a difference, it is probably the perfect ride heigh you are looking for too. I have a set of s-line springs in my garage but I need to swap them out at the end of my lease.
    APR 93// APR Exhaust// APR testpipe//H & R Sport Springs//19'' Gunmetal VMR RS4 Rims//Kumho Ecsta SPT// Podi Electronic Stepper Boost Gauge// Smoked Tail and Headlights//Debadged//Color match reflectors
    Jan 01 2008
    Long Island NY
    non sline is a lot higher. Dont bother getting s line springs though just get some H&R's.
    Non S line Ride Height:
    Jul 27 2008
    long island
    Quote Originally Posted by Ivory 305 View Post
    yeah i think that is the ride height i am looking for. are the shocks different too.
    Sep 10 2007
    Miami, Florida
    Quote Originally Posted by amt2007s View Post
    I am not sure about the shocks but I am sure someone on here can answer that for you, the s-line ride height looks a lot better.
    Jan 01 2008
    Long Island NY
    S line shocks are stiffer than the non Sline ones but you should be ok with the shocks you have.
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    if you put sline springs on, your stock shocks will be running lower than they are used to. you should be ok for a while, but you do run the risk of blowing your shocks and eventually getting a crappy ride...
    no point in buying just sline springs. check the classifides and find someones sline suspention and install the sline shocks and springs. it wont be that expensive.. it usually sells on here for around $300 or so. i got an sline suspension from someone on here for $175. just check around and you can find a good deal
    A LOT of people sell them. since almost everone on here drops their cars, they always sell their old sline suspension instead of letting it collect dust in the garage
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Quote Originally Posted by Auditude2.0T View Post
    what offset are your bimotos and do you have any rubbing issues with h&r's?
    Jul 27 2008
    long island
    any one want to part with there s-line springs and shocks
    Jan 01 2008
    Long Island NY
    I have 43 offset in the front and 23 offset in the rear. H&R Sport Springs with very very minor rubbing with big bumps in the rear with 4 people in the car. I have 18x8" with 235/40 tires.
    Registered Member Two Rings audibehr's Avatar
    May 29 2008
    2008 a4 tit,s line
    san francisco
    I have the full s-line package, with titanium, I want to drop my car a bit as well, am definatley going with springs, the streets in frisco suck as much as some of the residents! I figure that using my car to commute, I don't need to do the whole c/o thing, good luck with what you pick, but like I said I have the s and want to go lower....
    May 21 2008
    23 offset? do they even make a wheel like that? I thought that 35 is the most extreme. Anyway do you rub in the front or back?
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Quote Originally Posted by ibiski View Post
    He's running 20mm spacers in rear.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    does anyone know the actual ride height (ground to fender) of the stock and the sport suspension?
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    I just measured mine (S-Line) a couple days ago, and I had 26 in. up front, 26.25 in the back.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Jul 27 2008
    long island
    any body know if the s-line quattro and cvt are the same suspension. I would think the front springs are stiffer on the cvt
    May 19 2008
    PA
    I live in PA and the road suck here as well, so I did the same thing. I have a non sline and put sline springs and shocks on, my front wheel gap went down 3/4 of an inch and the back dropped 1 full inch. I like the look, perfect for me expecially with the shitty roads and snow up here. I would suggest getting the springs and shocks...like stated before you should be able to get them somewhat cheap on line here but get the complete package! Have Fun!
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    The Sline springs are a good option, coupled with the stock non-Sline shock you will notice no difference in ride, and contrary to what some will say it isn't drastic enough to ruin the stockers.
    Another option is the Eibach Prokit, its not a drastic drop (~1.5"), but it does require new shocks at the same time.
    Jul 27 2008
    long island
    Im going to go with the s-line springs and shocks.
    Now who wants to sell there's?
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by CardNation View Post
    Not trying to be rude but anything to back this up? A .75" difference is enough to blow out the shock given enough time. Plus, most people sell their sport shocks and springs together so you might as well get both.
    Thats what I'm rocking. I had sport suspension and HAD to go lower. Its only a modest drop and I drive around NYC all the time and have never scraped.
    Registered Member Two Rings tech_frog's Avatar
    Jun 09 2008
    Fort Worth
    I am also willing to buy someone's s-line springs and shocks......I don't want anything lower than that.
    Hey yall, watch this.......
    The Stable
    08 A4 2.0 Dolphin Q-Tip + APR
    08 Wexus RX-350 (Wife's)
    04 WJ Jeep GC Overland (doesn't use much gas while sitting in the garage)
    06 C55 (Gone, but was a blast!)
    04 A4 3.0 Ultrasport (Gone)
    May 19 2008
    PA
    Once again, get both if your going to do it.... even if your just upgrading to the sline sport suspension get the springs and shocks... like I mentioned earlier my back dropped about 1 full inch... I would say especially if you have people in the back (often) I would get the shocks also.....
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    I have a set of sline shocks and springs. I am willing to sell them. If anyone is interested PM me. I would prefer local pick up.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Jul 27 2008
    long island
    yea. im definitely going to do the shocks also. probably the sway bar too.
