Results 1 to 9 of 9
    Active Member Two Rings brown_Guy1's Avatar
    Jul 21 2008
    2013 Audi Q7; 2010 Audi A6 3.0T; 2010 Porsche Cayenne; 2016 Lexus IS200T
    Jacksonville, FL
    Gear Grinding?!?!?!
    Hey Guys...I'm new on this forum and even to the German world...I've been driving toyotas for the past 7 years and decided to go with an A4 with my last car purchase...I picked up a 05 A4 6spd manual....now to the problem....sometimes when i shift into 2nd and 3rd the gear seems to grind for a split second and then goes in...at first i thought i was just shifting before the clutch was fully in but then i started paying attention...turns out then when I try to shift quickly that's when it happens...for example if shifting from 2nd to 3rd if it's one straight motion 2-3 then there's a bit of a clink but if i let the shifter slip out of 2nd to neutral then push it into 3rd slowly theres nothing....anybody have any idea as to what this could be? cars only abut 2 weeks old for me now
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Gear Grinding?!?!?!
    Quote Originally Posted by brown_Guy1 View Post
    Bad synchros.
    You could try doing new tranny fluid
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Is it still under warranty? CPO?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 21 2008
    Jacksonville, FL
    ye it's under the regular factory warranty until December of this year...would it be covered under warranty?
    Sep 24 2007
    Woodbridge, Ontario
    Quite possibly!!!
    Jul 21 2008
    Jacksonville, FL
    I see...I guess I could take it into the dealership and see what they say...otherwise how much roughly would an install for new synchros cost me?
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    this exact same thing happens occassionally with my VR6. It doesn't happen all the time but i notice it every once in a while. Sounds like the same thing as what's happening with mine. I've never bothered to have mine looked at since it rarely occurs but mine is from 1st to 2nd gear. Usually at lower rpm's, such as when i shift in between about 2500 and 3000 rpm's it'll grind a little bit. I have never been able to figure it out but it hasn't been an issue.
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Courtesy of CO AVANT
    "Try to re-align your syncros. When sitting at idle press in the clutch and quickly shift from 1st to 2nd to 3rd to 2nd to 1st. Do the same 3rd to 4th to 5th to 4th to 3rd gear."
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Here is what happened to me, kinda started the same
    http://www.audizine.com/forum/showthread.php?t=218214
    Its only a few posts down under transmission trouble if the link didn't work
    Please Drive Right
