Results 1 to 10 of 10
    Registered Member Two Rings dustind's Avatar
    Jul 21 2008
    2008 A3 2.0T DSG - Lava Gray
    San Luis Obispo, CA
    Headlight Switch
    I'm starting to work on my new A3 to fit in a few upgrades and I had a question about the headlight switch. There is a symbol to the left of the switch but the switch does not turn to the left. This looks like a fog light symbol. My A3 Premium package does have fog lights. I've seen an upgrade part at OEMPL.US that says it adds full functions. Anyhow just wanted to see if anyone had some insight on this little piece. Thanks!
    Veteran Member Four Rings jefferson88's Avatar
    Feb 12 2004
    08 A3 2.0T S-Line
    G-town, Ontario
    Re: Headlight Switch
    it lights up when you put the fogs on... which you do by pulling the dial outwards
    Past: 99.5 A4 1.8TQ, 07 A3 2.0T
    Present: 09 A4 Avant 2.0T & 08 A3 2.0T S-Line
    Veteran Member Four Rings krazyboi's Avatar
    Oct 24 2006
    NoVA
    correct, you can't move the switch to the left...and as jefferson88 stated, it just indicates that if you pull it out, your fogs will turn on.
    i'm not positive, but the oempl.us one might have two of those symbols. if so, the lower one just indicates that you can have rear fogs enabled.
    Jul 21 2008
    San Luis Obispo, CA
    Yeah I was thinking that might be it since it's the same switch that I had on my old 2000 Passat. The placement of the symbol just seems counter intuitive.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    krazyboi is right about the 2 fog symbols on the OEMpl.us switch. It has a two stage pull out. First notch puts on the rear fog (highly confusing to USA drivers) the second notch adds front fogs.
    Not sure if this works on the A3 but my older S4 will allow you to turn on the front/rear parking light if you move the turn signal stalk to the the left turn or right turn position and take the key out. Left illuminates the left lights and right illuminates the right lights. Handy for parking on a narrow street and want people spot your car.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Jul 21 2008
    San Luis Obispo, CA
    I'll have to take a closer look at it and see. I like the metal trim (which the stock does not have).
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    when i pull my, 1st notch is front fogs 2nd notch is rear
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by tpliquid View Post
    oops, you got it, works that way on my S4, sorry...
    Does yours do the parking light thing?
    The Avant Garde
    Oct 24 2006
    NoVA
    ^^^ gotta test that parking light thing you speak of... so, i put the turn stalk into whichever position, remove key, and the lights should remain illuminated? how long do they stay on?
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Quote Originally Posted by dustind View Post
    Speaking from my own personal experience (since my Passat is A5 Golf based also)....the "Full Function" is misleading because, the way the car is programmed, may affect function of the euroswitch:
    For example: with North American DRLs enabled:
    Off = DRL
    Middle (parking) = DRL
    Full on = low beam and the rest of the lighting (including fogs if you pull it out).
    Double check with the VAG-COM with the long-coding helper to see what you can do.
