Results 1 to 31 of 31
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Urgent Help: Can't get car in first gear. [updated, still need help]
    Cars 5 spd transmission has been acting weird lately.
    Well tonight on way home I came to stop. I cannot get it in first gear to save my life. I can force it into something higher and try to launch like that.
    When car is not started gears seem to shift fine.
    OK, so I can put the car in 1st while off, and start it and take off like that. Feels weird, but works. I can also get to all the gears except 1 when car is on, just a bit hard to get to.
    What does this mean?
    How can I check fluids? Pedal feels spongey
    Plz help, this is my only mode of transportation. :(
    Oct 08 2007
    cali
    Re: Urgent Help: Can't get car in first gear.
    sound like the clutch master cylinder
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by trev0006 View Post
    Expensive to fix?
    May 24 2007
    Southern California
    Quote Originally Posted by jbrown7815 View Post
    Expensive to fix?
    shouldnt be too bad if you can do it yourself.
    i just had to do this with my tacoma. it was actually pretty fun trying to out smart the bad master cylinder. for example i only had about 2 seconds of clutch depression before it started to grab again by itself. so i had to shift super fast. starting was the best part, i'd be at a light in neutral and have to put the clutch in, get it in gear and let the clutch out before it stalled itself. did that for about 2 weeks. fun stuff.
    Kyle
    2.0L Revo GTRS Eliminator
    Mar 12 2008
    Portales, NM
    I don't know what I'm doing enough to do that.
    Is it just replacing a part? I don't have the money for something like this.
    Why does this shit happen to me. :'(
    Mar 12 2008
    Portales, NM
    May 24 2007
    Southern California
    for the toyota, i think it was only around 70 bucks, but i have no idea for this german car we call audi.
    Kyle
    Mar 12 2008
    Portales, NM
    But of course I don't even know if the this is actually the problem.
    May 24 2007
    Southern California
    try seaching. im pretty sure this happened to someone else.
    Kyle
    Mar 12 2008
    Portales, NM
    I'm not seeing anything..
    May 24 2007
    Southern California
    http://audizine.com/forum/showthread...ck+parking+lot
    this is the one i was thinking about, but i searched "stuck in parking lot" lol. cuz i remember him saying that.
    Kyle
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I had the same problem last year and it ended up being a being a bad clutch. I was told at the time that it also may have been a bad slave cylinder. If the pedal feels different, that may be the problem.
    Feb 17 2005
    Sarasota, FL
    Are you still on the stock clutch? With the car off, does it go in first? Start the car in 1st, can you let out the clutch and take off like normal?
    Active Member Four Rings Ptwiggens's Avatar
    Jul 20 2005
    APR Stage 3+ '02 1.8TQM A4
    Colorado/Manhattan
    Quote Originally Posted by A4ringedONE8T View Post
    I was about to ask these questions!
    Bam!
    Mar 12 2008
    Portales, NM
    Yes stock clutch. Yes car goes in first when off. Going to try this now.
    Mar 12 2008
    Portales, NM
    Mar 12 2008
    Portales, NM
    Well, BRB, going to try and run it to stealership see what they say...
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It means that your clutch is dragging (not fully disengaging). The reason you can shift after you are moving is because the synchronizers can force the input/output shafts to match speed. You can't get it into first since the output shaft is not moving at all. your problem is one of two things. You could have a hydraulic issue where you master cylinder or slave cylinder isn't working properly. If this is the case you are probably experiencing a very low clutch engagement point. Typically as the clutch wears the engagement point gets higher, not lower. If it isn't a hydraulic issue then you will need a new clutch.
    Mar 12 2008
    Portales, NM
    Ok so I just took it to the dealership.
    Everytime I came to a stop I had to cut car off to put in first,
    Then Right when I got there, it started acting normal[ish] again.
    On drive home I was able to get into first while on easily, as long as I wasn't moving or going very slow. The rest of the gears felt almost normal.
    Dealer guy said it probably is clutch, but he didn't even look at it.
    What now?
    Dec 28 2006
    Western Maryland
    Re: Urgent Help: Can't get car in first gear. [updated, still need help]
    At what point in your clutch pedal travel does the clutch begin to engage? Just off the floor, halfway up, or closer to the top? Typically the stock clutch engages around halfway to 2/3 of the way up. If your clutch engages very low I would suspect the clutch master cylinder or even possibly the throw out bearing. Are you getting any noises when depressing the clutch?
    Mar 12 2008
    Portales, NM
    I barely barely let off the clutch before it starts engaging. I can kinda hear some clicking.
    Dec 28 2006
    Western Maryland
    That is definitely not normal for a stock clutch. The clicking is also a concern. If the throw out bearing is shot it lowers the stack height of the clutch/pressure plate/TO bearing assembly and causes a low pedal and is usually accompanied with some noise. A worn master cylinder can also cause a low pedal. You can perform a quick (and crude) check on the master cylinder like this: Motor on, in neutral, rapidly pump the clutch pedal several times and on the last pump try to put it in first gear. If it goes in easily you probably have a hydraulic issue. If the engagement is still poor you will most likely need to replace your clutch.
    Mar 12 2008
    Portales, NM
    . Since I took drive to dealer, it gets into first easily as long as I'm not moving... while started or not.
    Dec 28 2006
    Western Maryland
    Try pumping the pedal as I previously suggested and see if it raises the engagement point any. If it does it's a good indication of a hydraulic issue that probably isn't going to go away on its own.
    Edit: Although it may be working now, a low engagement point with a stock clutch is not normal. It would be best to figure it out now before it leaves you stranded.
    Mar 12 2008
    Portales, NM
    Alright, I'll give that a try. Hopefully it stays driveable like this for a bit.
    I don't have money to replace clutch right now.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    My guess is either Slave/Master or clutch. That test that Old guy said should give you an idea what your up agaist.
    I had the slave go on my jeep 3 times, what a pain in the ass that is because its internal to the tranny had to drop the tranny and transfercase.
    Mar 12 2008
    Portales, NM
    It's acting normal now.
    when I release the clutch, it kinda shakes a bit until fully engaged.
    WTF?!!?
    Dec 28 2006
    Western Maryland
    WTF?!!?
    Hate to say it but I recommend you start saving your $$$ because a new clutch assembly is in your near future. Hydraulics are not going to cause shuddering. Defective clutch will.
    Mar 12 2008
    Portales, NM
    Great, well I think I'm going to go with the Southbend FE SS
    How much does it cost to get flywheel resurfaced?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Good choice on the clutch. Southbend will resurface your flywheel for free and ship it back to you with your clutch.
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by Condo View Post
    Oh sweet.
    I just don't wanna buy the clutch until I know that it's the problem..
    It seems to work fine right now.
