Results 1 to 8 of 8
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    rocking/creaking noise at low speeds
    describing these things in words is always a disaster, but gotta give it shot... it usually seems to work out in the end...
    at low speeds, say below 15mph, i have been hearing a sort of creaking/rubbing noise. not rubbing from being too low (all too familiar with that sound), but almost like the sound it makes when you clean your windshield it gets "squeaky" clean only a little deeper pitch.
    the most common time i hear it is when i let off of the brake. so if i'm driving 20, and then brake firmly, when i let off the pedal it will make the noise.
    i also sometimes hear it when i lightly step on the gas.
    the sound typically seems to come from the driver's side wheel well area... seems like in back more often, but it's really hard to tell.
    i was hearing this before, but after getting coilovers it seems to be more pronounced and happening when riding over slightly bumpy ground at low speed as well. so it's probably not the springs since they've changed and the sound hasn't. i wonder if it could be the engine mount since i just had some work done to the engine at the dealership and it started right after that. possibly some other suspension component? control arms, bump stops?
    any ideas appreciated!
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    Re: rocking/creaking noise at low speeds
    mine does it on left hand turns..suspected that something is touching a tie rod from it being lowered..not sure though
    Oct 08 2007
    cali
    maybe the brakes are done
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    One of two things. The sliding single piston calipers on this car are famous for making noise as the pads start to wear - this does not mean you need new pads. My B6 S4 and many many thers had this noise. The B7 A4 has the same caliper. It can also be your control arm bushings. Did you reset your control arm bushings to a nuteral position when the car was lowered? If not, I'm guessing you bushings are shot. The stock bushings are crap on this car and do not last very long.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    My rear brakes make kinda a low vibration sometimes, i dont really worry about it.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    Control arm bushings is the likley culprit. I have the same issue on my 02 GLS Jetta. It's a common ailment in the VAG world.
    Usually if I let the car sit for a few days it goes away, once I start driving over rough dipping terrain it comes back.
    The squeaking is coming from the front and rear driver side on mine as well.
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    bummer. i should have got it looked at before putting the coils on. sure it won't be covered by warranty now. any idea how much replacement would cost if it is control arm bushings?
    Mar 19 2007
    Apparently what happens is the bushings get torn and then you have slight metal to metal on the control arm which is what causes the skweaking noise.
    Unless you are so inclined as to change the bushings yourself, which is not that easy, it's a lot easier to just buy new control arms and swap them out. They shouldn't cost anymore than 80 a piece.
