Results 1 to 15 of 15
    Apr 22 2007
    Riverbank, Ca
    Apexi AVC-R Install: Anyone Do it?
    Anyone have a how to to install this beast?
    I cant seem to find much on a search.. and not a whole lot on the internet...
    Im mainly concerned about the wiring... which wires to patch into.. like tach, speed sensor, ect..
    Andrew
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: Apexi AVC-R Install: Anyone Do it?
    I have done the install... I have everything hooked up except the TPS (throttle position sensor) I got all the wiring from the back of the cluster. The colors vary from year to year i think... The speed sensor is way off on the AVC-r compared to what signal the cluster is getting. I just need to find the wire for the tps and I would be all set... I will try to look tomorrow to see the wires I tapped into on the back of the cluster...
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    I have it, have everything hooked up on her. Tapped into right by the ecu.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    I have it and everything except for the VSS hooked up.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    your avcr looks cool... i want the blacked out one now :(
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by t1demont1 View Post
    I was bidding on one on Ebay but that friggin Ebay sniping shit got me
    - Clint
    Feb 27 2005
    North Wales, PA
    MUAHAHAh it was me
    just kidding...but I just sniped a fully working cluster with a perfect display for $79.
    Apr 22 2007
    Riverbank, Ca
    So how do I deterimine what wires to tap into? The Hanes manual?
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    this may help if you havent found it already
    http://www.audizine.com/forum/showth...ht=safc+wiring
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Apr 22 2007
    Riverbank, Ca
    Ohh thats going to definately help!
    Sep 24 2005
    always in design
    I love it, I may mount in the cup holder under the center armrest if I ever get motivated
    Jan 26 2006
    2001 A4 1.8T
    Socal
    this is where I put mine
    I am going to make it so it will disappear, kinda like the cup holder does above. so you would push it and it will pop out.
    Mods:
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    i was thinking, when/if i ever install mine, of velcroing it to the bottom of the armrest, so it can be removed to use
    Apr 22 2007
    Riverbank, Ca
    I was thinking of mounting mine where the factory cup holders are (the ones that dont do anything..) to the right of th Ebrake. Push on the two pop ups and out pops the boost controller!
    Apr 22 2007
    Riverbank, Ca
    Damnit I cant find my haynes manual...
    Anyone have a drawing of the ECU code pins for the 98 AEB? (1.8t manual quattro...)
