Results 1 to 13 of 13
Thread: overheating
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    overheating
    So I was driving and all the sudden my coolant temp shot straight to hot. I pulled over and shut her off. I started her up dorve her a bit and the temp slowly started to climb. So I will be getting her towed home tonight and start ripping her apart tomorrow.
    Sorry for any spelling errors I am posting this from my blackberry.
    I figure the problem lies in the water pump. Any input would by great.
    I did a search and came up with possibilities
    Thermostat
    Water pump
    Fan switch
    Fan
    -Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: overheating
    T-Stat would be my first check. But I think you covered the list very well, maybe coolant level? BTW, turning on the heater may lower your engine temp, to prevent it from getting way too hot, in time for you to pull it over and have it towed.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Dec 06 2007
    Re: overheating
    same happened to me, my waterpump blew and no matter what i did temp went straight up!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: overheating
    add Temperature Sensor to the list. this is a very inexpensive and easy part to replace, and is especially common in B5 models. but overall your thermostat is probably stuck in position causing the car to run hot. i doubt it's a bad water pump. more often than not when this goes bad your engine will react much more severely than just overheating. blowing a water pump will cause thousands in damage...
    how many miles do you have on the car?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: overheating
    H2O pump....
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Re: overheating
    Could also be a bad head gasket.
    Mar 04 2004
    Alaska
    Re: overheating
    77k on the car. I don't know if the timing belt or water pump have been changed. I bought the car with 76K on it. I was planning on ordering the kit monday to for the water pump, timing belt and everything else. Hopefully I prevented a potential major issue.
    If I recall correctly if the head gasket blew my exhaust would be bellowing white smoke? Which it was not doing.
    Also I talked to a couple people and was told that if the water pump had completely failed the coolant temp would have gone to hot more quickly then the gradual heat increases that i was getting.
    -Sean
    2002 1.8TQM
    On Order
    Rims/Tires
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: overheating
    Dont scare him with the whole headgasket crap, lol
    Most likely the plastic water pump, broke apart....sounds like u know what your doing anyways
    -Sami-
    Aug 26 2005
    Re: overheating
    It's academic, but when coolant temp climbs to Hot at above idle speed, and can be somewhat cooled by using the heater on High, then it's likely the coolant pump impeller is cracked and slipping on the pump drive shaft at speeds above idle. The other case of the broken plastic impeller is when the coolant temp climbs no matter what the RPM, or if the heater is ON, instead of being cracked, it's actually broken in two, and separated from the drive shaft completely. In that case the heater can't help because there is no coolant flow at all. Never add coolant to an system that has overheated/boiled over, without allowing the engine to cool down for at least a half hour or longer first.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Re: overheating
    lol it was just a suggestion... ive had mine goout on me before
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Re: overheating
    Someone selling a car at 76K most probably did NOT have the timing belt replaced, so def do that.
    The B5 also had a problem with the coolant flanges cracking, especially after the car overheats (this according to an Audi tech), and it's a low cost part. If this is common with B6's (I'm not sure if it is though), then perhaps replace that as well.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Re: overheating
    OK, well you scare me when you say don't scare him with the head gasket crap, I was just told a few minutes ago I have a blown head gasket.
    Senior Member Two Rings tbaggs's Avatar
    Oct 17 2004
    2002 A4 1.8T Q M
    Anaheim Hills, Ca
    Re: overheating
    Quote Originally Posted by windyctyaudi View Post
    +2 check for a blown gasket asap before anymore damage is done
