Results 1 to 8 of 8
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    ABS and e-brake light blinking problem
    this one is a new one for me.... uhhh started my car up and in the first few seconds the abs and e-brake light blink and make the beeping sound... ideas anyone?? happened about 3 times to me so far
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: ABS and e-brake light blinking problem
    how many beeps? if its three then you need a new abs module.
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    research it...
    check your brake fluid, more than likely, new abs module
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    3 beeps, module is dead.
    ThorTechnik.com
    Oct 08 2007
    cali
    my friends car was the module
    Aug 01 2007
    2000 S4
    Daly City
    what does 1 beep and 2 beep stand for then?
    Sep 21 2006
    Norjerz
    "we are beeps 1 and 2 of three beeps you will hear when your abs module is fucked."
    ...i dont understand the question...thats like having a car that dings when the seatbelt is off and asking "what are the 5th through 9th dings trying to tell me?"...the same thing the rest of them are.
    SBSC
    Active Member Two Rings jlyv3845's Avatar
    Jun 12 2007
    Massachusetts
    ya abs module. if you have one, vag-com it and if it doesn't pick up any problems you probably need a new abs pump control unit:
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
    not a guaranteed fix but it's your best bet if vag-com isn't showing anything. the traction light will also come on with this issue if you have one of the later s4's with ESP (but you have an 00 correct? so i suppose not in this case). there also could be an issue in the hub where 2 parts become separated over time. i don't know a lot about that one but i know that can also mess up your abs and make the light's go on, but you have to check all 4 hubs for it though. hope this helps.
    Josh
