Results 1 to 13 of 13
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    adjusting the toe?
    anybody know how to adjust the rear toe?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: adjusting the toe?
    There is an eccentric bolt that must first me loosened, and then you can adjust.
    If you are standing behine the car, looking towads the front, the eccentric bolts will be on either side in front of the lower control arms
    -Sami-
    Feb 19 2007
    Louisiana
    these??
    Feb 19 2007
    Charleston, SC
    /\No
    Its just one bolt, but its kind of tucked back in there...
    I will try to take a pic tomorrow
    -Sami-
    Feb 19 2007
    Louisiana
    ok thanks
    Feb 19 2007
    Louisiana
    Feb 19 2007
    Charleston, SC
    Sorry no,pic
    But yes,i do believe the is the bolt.
    -Sami-
    Feb 17 2005
    Sarasota, FL
    Sorry no,pic
    Thats the rear subframe bolt, are you sure you're not thinking about the eccentric camber bolt?
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by A4ringedONE8T View Post
    Yea.
    The OP is wanting to adjust the rear toe. Which is adjustable. The pic above obviously isnt of the eccentric bolt for the toe. (My mistake) It's kind of hard to tell from where the OP is taking the picture from. But I guess that obviously isnt it, because the washer around the bolt isnt eliptical.
    OP, I will try to get a pic of where it is tomorrow.
    The best I can do to descibe its location is look where one of the halfshafts are, and look above that but behind the hub.
    -Sami-
    Jul 20 2008
    libertyville,IL
    what would addjusting the toe do? (sorry im brand new to the audi world, I used to be a subi guy...movin up in the world)
    Feb 19 2007
    Charleston, SC
    -Sami-
    Feb 19 2007
    Louisiana
    the eccentric camber bolts only allow to adjust the camber not the toe rite?
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by plokm View Post
    There are two different bolts. One for the camber at the back of the hub. And one for the toe, located on the hub facing the front of the car.
    Heres a pic of where they would be (follow the lower control arms back and look for an eccentric bolt)
    -Sami-
